All Targas Flex or do they! |
aveale |
Aug 16 2006, 09:59 AM
Fun Times Group: Members Posts: 194 Joined: 18-August 04 From: Ottawa, Canada Member No.: 2,563 |
they all flex.
anyone who says otherwise is in denial...or has a full cage. T |
maf914 |
Aug 16 2006, 11:37 AM
they all flex. anyone who says otherwise is in denial...or has a full cage. That is correct. They all flex. With or without an Engman kit, Meyuer clamshells, welded metal 916 roof, full cage, half cage, no cage, you name it. It's all a matter of degree. But, obviously, some flex more than others! (IMG:style_emoticons/default/laugh.gif) |
John |
Aug 16 2006, 11:57 AM
If you can't measure the deflection (all steel car bodies deflect), then either you don't know how to measure it, or your measuring equipment isn't precise enough.
tracks914 |
Aug 24 2006, 06:55 PM
Canadian Member Group: Benefactors Posts: 2,083 Joined: 15-January 03 From: Timmins, Ontario, Canada Member No.: 153 Region Association: None |
I thought 31% seemed high maybe just a bit of denial going on here.... or 1/3 of all cars are race cars?
BTW the pole was with the jack on the rear donut and both wheels lifted off the ground. |
budman5201 |
Jan 6 2010, 08:15 PM
Senior Member Group: Members Posts: 595 Joined: 1-April 07 From: tempe, az Member No.: 7,635 |
now can i add a roll bar like this that is attached on the front also, i bet that will eliminate flex!
plymouth37 |
Jan 9 2010, 02:05 AM
Senior Member Group: Members Posts: 1,825 Joined: 24-May 05 From: Snoqualmie, WA Member No.: 4,138 Region Association: Pacific Northwest |
I can't see any flex in mine, the 12 point cage doesn't hurt things either...
Lo-Fi Version | Time is now: 23rd May 2024 - 04:57 AM |
