> POP! goes the 1st gear, Trans is shot
sportlicherFahrer
post Aug 15 2006, 04:20 AM
Nothing to see here.
I know my trans is bad now that it pops outta 1st and makes it hard to find other gears after that. If I dont go for 1st and drive like she's a 4-speed, I still get hard shifting, but the gears are there and easy to find.
I am believing it to be the cause of the main bearins going out. Trans has been noisey for the last year or so. It is like a loud gear whine. Pitch/volume go back down with each gear. Also seems to be "hanging up" when in gear sitting still. Earlier today the car would roll back on a slight hill FREELY when I had my foot on the clutch while in gear. Now with it in gear and clutch in, it kinda sticks and makes the car stop moving LIKE it had a bad caliper.
I am already workin on gettin another trans in there, but am wondering if my diagnostic sounds correct. Can the main bearings going bad cause Fuched shifting and the other symptoms? If not, what kind of other ideas are out there?
Just curious (IMG:style_emoticons/default/confused24.gif)
Afterthought!!!
I know that the oil is ok. I changed it a few thousand ago and put in Lucas. I didn't run it low AT ALL.
Bleyseng
post Aug 15 2006, 07:59 AM
Aircooled Baby!
You are probably right about the bearings cuz when they are shot there is tons of slop and the mainshaft will flop around causing engaugement problems.
If you pull it and drop it off I could pull it apart and tell you exactly what is wrong with it.
- Lo-Fi Version Time is now: 16th July 2025 - 03:59 AM
