GT Brass Oil lines, Anyone make these? |
kckoch |
Aug 15 2006, 10:26 AM
Member Group: Members Posts: 98 Joined: 16-March 06 From: West Palm Beach, FL Member No.: 5,731 |
Any body know a source where I can have these made? Does anyone make repros?
BenT |
Aug 15 2006, 02:15 PM
realty check casher Group: Members Posts: 103 Joined: 21-June 06 From: San Francisco Member No.: 6,273 Region Association: None |
Guy out East that did Pete's car makes them... don't remember his name. Martin can chime in with the info. From what I understand, he may make them "occasionally" and in batches. I'm up for some smoothies depending on price. Fins look awful after a short time. Plus crub build between them. BenT B. Rasspipes |
ChicagoPete |
Aug 15 2006, 02:30 PM
Member Group: Members Posts: 227 Joined: 10-January 05 From: Lake Forest,IL Member No.: 3,427 |
Yes, Mark made mine and has all the measurements off an exact GT set...
Mark Allin of Precision Automotive Restoration 978.463.8144 Hard to give you guys a guesstimate on price, they were at least $500 2 years ago, BUT, you have to also figure that I was paying him at shop rates for fabrication as he did the WHOLE car for me. What he will sell these parts for outright and if he has the time to fab some up I can't answer that question. Peter |
brer |
Aug 15 2006, 02:40 PM
Advanced Member Group: Members Posts: 2,555 Joined: 10-March 05 From: san diego Member No.: 3,736 Region Association: None |
smdubovsky |
Aug 15 2006, 02:46 PM
Member Group: Members Posts: 331 Joined: 27-September 04 From: Silver Spring, MD Member No.: 2,837 Region Association: MidAtlantic Region |
QUOTE why? They do the job better than smooth. looks? Yup. Plus, w/ a cooler up front they are unnecessary. SMD |
Eric_Shea |
Aug 15 2006, 02:59 PM
PMB Performance Group: Admin Posts: 19,278 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
Period looks
Real cooler up front Fins get smashed Fins get full of stuff |
BenT |
Aug 15 2006, 03:14 PM
kckoch |
Aug 15 2006, 04:12 PM
Yes, Mark made mine and has all the measurements off an exact GT set... Mark Allin of Precision Automotive Restoration 978.463.8144 Hard to give you guys a guesstimate on price, they were at least $500 2 years ago, BUT, you have to also figure that I was paying him at shop rates for fabrication as he did the WHOLE car for me. What he will sell these parts for outright and if he has the time to fab some up I can't answer that question. Peter Thanks Peter, Mark is ready to make some and would prefer to make 3 or more in a batch. They are smooth, and are just as the picture above. $650 a set. I'm in, now I need two more. Any takers? |
michel richard |
Aug 15 2006, 04:20 PM
Senior Member Group: Members Posts: 1,291 Joined: 22-July 03 From: Longueuil, Québec Member No.: 936 |
I made my own out of hadware-store steel tubing. Had to make a couple of mandrels to be abloe to get semi-smooth bends. They came out ok, I think, but it was a lot of work.
michel richard |
Aug 15 2006, 04:21 PM
and:
Mueller |
Aug 15 2006, 05:24 PM
Hmm.. It looks like it would be possible to make you own.... Anyone have pipe sizes? not sure of the size, I'm sure someone has to have it written down (IMG:style_emoticons/default/smile.gif) McMaster-Carr has 1" OD brass alloy 260 for about $50 for a 6' length (.065 wall which might be overkill, .032 is about half the price) they mention that is not bendable however one might be able to anneal it... |
michel richard |
Aug 15 2006, 06:56 PM
My stuff is one inch od.
Pretty much the maximum that will fit under the rockers, I think. Michel |
kckoch |
Aug 15 2006, 07:39 PM
I have thought long and hard about making them myself, and decided to let someone else do the guessing. He uses the factory GT specs, a little expensive, but they are the real deal. He only makes a batch about every two years. He said that the stock (brass) he uses, he ordered 9+ months ago, and it just arrived. He planned on just waiting until he had enough interest.
Any takers? I still need two more? |
ChicagoPete |
Aug 16 2006, 07:06 AM
Kevin and others...The question you have to ask yourself, "How authentic do you want to look?" "What are you trying to achieve with your car?"
The point being...yes the the cooler lines are cool, but, honestly, on a previous big six that I owned I ran Aeroquip fittings and braided lines to a Mazda comp cooler and that worked just as well as these! Where do you draw the line...between cool parts and what works just as well? I have at least $5000 into my oil sytem. Shroud, 906 cooler, authentic fabbed flex lines, hard brass lines, oil filler neck, blau cap, magnesium 911S thermostat, oil pressure relief valve, and the overflow tank in the trunk. I wanted everything to look as authentic as I could! And for standard 914 guy all of this is lost unless you have an appreciation for true 914-6 GT racing equipment. By no means am I trying to take away business from Mark. For my money the cool factor goes way farther on something you can see. Maybe a well made engine lid, GT door panels, or even better an authentic GT steering wheel with the extra padding and the proper horn button. Peter |
fin |
Aug 16 2006, 07:26 AM
Newbie Group: Members Posts: 47 Joined: 3-January 05 From: MPLS, MN Member No.: 3,398 |
Not a fin fan either...
Fin gets smashed Fin gets full of stuff Um, are you guys trying to tell me something? And you haven't even met me..... Cheers, FIN |
Eric_Shea |
Aug 16 2006, 09:44 AM
Shhhhhhhhhhh Fin's here... (IMG:style_emoticons/default/biggrin.gif)
Morning Gents... I'm close on this one. Still pondering. One side says there's nothing wrong with some nice braided lines. The other side says... I spent $300 on some used 911 hard lines. $650's not all that bad for a custom one-off reproduction of the originals. I don't know how to describe it... I just like the idea of having hard lines down there. Close to throwing my hat in the ring. (IMG:style_emoticons/default/confused24.gif) |
BenT |
Aug 16 2006, 10:40 AM
I don't know how to describe it... I just like the idea of having hard lines down there. Hmmmmm (IMG:style_emoticons/default/idea.gif) So that's how you guys like it in Utah? As for the brAss lines, $500 already seemed to me a good upper limit. I mean these are repros!? $650 might only be a hair away but enough to buy a small toupee's worth of other goodies. The braided lines is starting to sound cool. BenT |
Brad Roberts |
Aug 16 2006, 11:04 AM
I had Chuck warmed up to make some 9146 hard lines. I highly suggest we go to someone who can knock these out repeatedly on a CNC tubing bender.
Armando also has a LA connection for making the lines. He made several sets when he was working on his car. B |
pete-stevers |
Aug 16 2006, 11:06 AM
saved from fire! Group: Members Posts: 2,642 Joined: 10-October 04 From: Abbotsford,BC, Canada Member No.: 2,914 Region Association: Pacific Northwest |
i am running copper not brass...regrigeration grade soft copper is easy to work with, and work hardens over time....but bends easily without pinching.
and a good silver solder keeps it all togther....and i also use a double braidhosing to get to the cooler and from the engine and to dampen vibrations.....and along the longs it is straight thick walled copper....it took us two evenings and a roll of soft copper and a few pipe fittings |
maf914 |
Aug 16 2006, 11:19 AM
i am running copper not brass...regrigeration grade soft copper is easy to work with, and work hardens over time....but bends easily without pinching. and a good silver solder keeps it all togther....and i also use a double braidhosing to get to the cooler and from the engine and to dampen vibrations.....and along the longs it is straight thick walled copper....it took us two evenings and a roll of soft copper and a few pipe fittings That sounds reasonable to me. I have a friend who used copper for the fixed runs and flex lines for the connections without problems. Copper does work harden, almost all metal does, but I don't think it's an issue unless the tubing is connected to a vibration source such as an engine or suspension member. Strapping it to the longs and fender wells shouldn't be a problem. At least that's my opinion. (IMG:style_emoticons/default/idea.gif) |
lapuwali |
Aug 16 2006, 11:30 AM
Aluminum is lighter than any of these, forms easily, and sheds heat well.
Lo-Fi Version | Time is now: 3rd June 2024 - 04:53 AM |
