GT Brass Oil lines, Anyone make these? |
smdubovsky |
Aug 16 2006, 11:52 AM
Member Group: Members Posts: 331 Joined: 27-September 04 From: Silver Spring, MD Member No.: 2,837 Region Association: MidAtlantic Region |
I said I was interested, but $650 is a little steep. If it was closer to $500 I'd be in. Should we contact Brads sources to see if we can get a run of something cheaper?
SMD |
Brad Roberts |
Aug 16 2006, 11:53 AM
and.... is used on ALL Porsche 993's/986/996/997
oil lines and water lines... all aluminum. B |
Brad Roberts |
Aug 16 2006, 11:55 AM
Chuck has the experience. I was going to foot the bill for several sets to be made by "Elephant Racing" New 9146 engine hard lines and GT style cooler lines with or without fins.
Chuck and I have been spending quite a bit of time at the track together. B |
sixnotfour |
Nov 7 2009, 12:58 PM
914 Wizard Group: Members Posts: 10,433 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
Chuck Moreland |
Nov 8 2009, 12:22 AM
Newbie Group: Members Posts: 22 Joined: 28-October 04 From: san jose, ca Member No.: 3,024 |
Our website is a little behind.
We now have the kit available with a front extension that arches over the wheel with hard pipe, up to the front. Attached thumbnail(s) |
Chuck Moreland |
Nov 8 2009, 12:24 AM
more
Nov 8 2009, 01:07 AM
Resident German Group: Admin Posts: 41,669 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Those look nice! (IMG:style_emoticons/default/beerchug.gif) Andy |
carr914 |
Nov 8 2009, 06:17 AM
Racer from Birth Group: Members Posts: 118,917 Joined: 2-February 04 From: Tampa,FL Member No.: 1,623 Region Association: South East States |
They look nice, but I don't know if they are $1,600 nice
Chuck Moreland |
Nov 8 2009, 03:46 PM
If you include the front wheel well extensions it goes about $2k.
What we set out to achieve was a super clean solution that looks and functions as if it was a production factory system, had they actually delivered up a production solution. I think we hit our mark. While not inexpensive, the kit is complete and inclusive of stainless mounting brackets, OEM porsche thermostat with pressure bypass, hoses, scavenge pipe, templates for holes, etc. All fittings and hose ends are 30mm as used by Porsche on all 2.4 and larger sixes. And the scavenge pipe fits both heat exchangers and headers. |
lagunero |
Nov 8 2009, 05:09 PM
Donkey Member Group: Benefactors Posts: 1,042 Joined: 8-January 04 From: orange county,ca Member No.: 1,531 |
I saw this set up at the last GAF and it's exactly what I was looking for. Since I had already installed a FMC, I spoke with Chuck and he helped me with what I needed. I'll post pics later this week.
It's worth it. If you haven't plumbed anything or like me, what the right look, it's worth the bucks. |
sixnotfour |
Nov 8 2009, 06:07 PM
QUOTE It's worth it. If you haven't plumbed anything or like me, what the right look, it's worth the bucks. definately a pro set up. chuck how does that coupling work near the jack post ? |
Chuck Moreland |
Nov 8 2009, 10:59 PM
Here is some detail on the couplng. Note the hard lines thread through above the jack receiver, leaving plenty of room for the rocker cover down low. No clearance issues.
The tubes have a bead roll on the ends to retain the hose section securely. The hose allows for chassis flex and easy install/removal. The hose is rated for oil and temperature, and we cap the ends to trim them out cleanly. The clamps are heavy duty, not wimpy worm drives. Note too the grommets where the hard lines pass through the rocker ribs. This prevents any rattling or potential wear on the tubes. Grommets also rated for tempurature. Attached image(s) |
Chuck Moreland |
Nov 8 2009, 11:33 PM
Here is the bracket that supports the thermostat and back of the pipes.
Stainless with rubber isolation around the tubes. There are 3 brackets total. 1 at the thermostat, 2 in the front well. Attached image(s) |
Chuck Moreland |
Nov 10 2009, 05:14 PM
Here is a shot of the thermostat mounting in the rear wheel well. Note the support bracket, which attaches to the existing suspension mounting hole.
This setup keeps the tstat out from under the car, easy plumbing underneath to connect the tank and engine case. Everything is tucked up tight, protected, and out of the way. No need to snake hoses down under the suspension, nothing vulnerable. Attached image(s) |
carr914 |
Nov 10 2009, 08:40 PM
QUOTE It's worth it. If you haven't plumbed anything or like me, what the right look, it's worth the bucks. definately a pro set up. Chuck, sorry if it sounded like a slam in my prior post. It definately looks Pro-Built. Question though - Why did you build it for the passenger side of the car vs the Drivers side which would be "Correct" to some people? T.C. |
RON S. |
Nov 11 2009, 10:50 AM
9140430841, FINALLY RUNNING Group: Members Posts: 1,212 Joined: 22-May 03 From: WALTERBORO,S.C. Member No.: 724 Region Association: South East States |
I have seriously looked into making my own set of -16 size brass lines for my /6r since this post was originally posted. I want the finned brass for mine, and found that I could get the material. Wolverine tube will sell it, and in Europe it can be had from Chrystin tube. I have a set fabbed up and was ready to send them to be professionally cnc formed, and the vendor didn't wanna touch it. I did talk to Chuck about buying raw material, but he was reluctant, and said that he only rec'd material once a year. I assume that the lines he's selling are -12. which unfortunately would be too small for my app. Good to see the thread is still alive. thanks, Ron |
Chuck Moreland |
Nov 11 2009, 11:39 AM
A number of considerations drove the passenger side decision.
The tank being on the driver side would not allow the type of tstat mounting we did. Even if we put the tstat somewhere else, the plumbing to and around the tank would have been crowded and convoluted. Already you have the tank-to-case oil line to contend with, then to compound this with pipes going to the front and the tstat is just messy. The front rib beneath the rocker panel is not the same on both sides. The passenger side is bigger and has room to squeak the pipes inside it. The driver side is shallower and would not allow this. The original GT solution is definitely full of retro-coolness if you are building a faithful GT replica. But it looks like an add-on put together by a raceteam (eg. hoses through the footwell, chopping the rocker ribs, crowded hose routing front and rear). Our goal was not to replicate the GT system, but rather view it as we think the factory would have - as a prototype to be refined into a production solution. We were striving for a GT inspired solution, developed into a production level system. That means minimal cutting of the car, no hoses in the cabin, no ground clearance issues, neat roomy hose/tube routing, clean factory appearance. |
9146BRUCE |
Aug 16 2011, 05:15 PM
Member Group: Members Posts: 57 Joined: 16-April 07 From: Northridge Calif. Member No.: 7,670 Region Association: Southern California |
Hi Eric did you ever get the hard lines made.
Bruce |
Eric_Shea |
Aug 17 2011, 01:22 AM
PMB Performance Group: Admin Posts: 19,278 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
Prototype set is done. From what I understand the buck (which is an actual 914 longitudinal) had to be moved from the shop where it was. We have about 6 orders deep right now... I'm trying to get a date myself. I'll keep everyone posted on what becomes of it.
JmuRiz |
Aug 17 2011, 08:06 AM
914 Guru Group: Members Posts: 5,433 Joined: 30-December 02 From: NoVA Member No.: 50 Region Association: MidAtlantic Region |
Wish I had $2k to spend on lines, that elephant system is very cool and clean.
Then again, I'm not even sure I'll need a front cooler for a 2.7. |
Lo-Fi Version | Time is now: 3rd June 2024 - 03:31 AM |
