Where's the good place to buy a lexan windshield? |
sww914 |
Aug 15 2006, 12:52 PM
for a 914.
nine14cats |
Aug 15 2006, 02:16 PM
Bill Pickering -- 914-6 GT aka....Leeloo Group: Members Posts: 2,618 Joined: 10-February 03 From: Campbell, CA Member No.: 287 Region Association: None |
grantsfo |
Aug 15 2006, 06:07 PM
Arrrrhhhh! Group: Members Posts: 4,327 Joined: 16-March 03 Member No.: 433 Region Association: None |
Wow is a Lexan window really worth $600 bucks? Is there a cheaper alternative?
brant |
Aug 15 2006, 06:44 PM
914 Wizard Group: Members Posts: 11,615 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
when doing race car projects its good to establish a $/lb formula that you are comfortable with.
our rule on the orange car was 50$/lb with that formula in place the windshield option would need to save 12lbs over stock to meet that rule. the GT-lexan lists at 11lbs |
grantsfo |
Aug 15 2006, 07:01 PM
when doing race car projects its good to establish a $/lb formula that you are comfortable with. our rule on the orange car was 50$/lb with that formula in place the windshield option would need to save 12lbs over stock to meet that rule. the GT-lexan lists at 11lbs I dont know sounds like its time for a plasma cutter and a trip to TAP Plastic! I'm more of a $10/lb racer! |
brant |
Aug 15 2006, 08:42 PM
In my class there are rules...
so to answer your question yes there are cheaper ways. I used them they require some research, patience, committment, and special tools. but well within the 50$/lb rule. brant |
jimtab |
Aug 15 2006, 09:02 PM
Advanced Member Group: Members Posts: 3,477 Joined: 5-January 03 From: Pacifica, California Member No.: 91 Region Association: Northern California |
Grant, I sell lexan at the store including 1/2" bullet proof stuff. CAll me at 415-861-1800...7am-3pm m-thurs this week.
byndbad914 |
Aug 15 2006, 09:10 PM
shoehorn and some butter - it fits Group: Members Posts: 1,547 Joined: 23-January 06 From: Broomfield, CO Member No.: 5,463 Region Association: None |
Wow is a Lexan window really worth $600 bucks? Is there a cheaper alternative? it seems like that is a decent rate assuming they use marguard (says "mar-resistant" on GT's site). I had a similar quote to make one locally with marguard (actually more than $600) so I will probably just get either of those. I paid way more to have the rear window done than those guys want (due to a "misunderstanding on my part" as they put it and hit me with an additional $120 "programming charge" they really didn't tell me about). So, to do it over again, I would probably just get the stuff from one of them. If I were to have them done in quantity, my pricing would be about the same as them. |
brant |
Aug 15 2006, 09:16 PM
yes coatings are an important part of it.
and plastic doesn't offer the same safety qualities. mine is 2 seasons old now, and pretty beat up. I recently got a new one for next year, mostly because my first one is so beat up that I wanted a spare on hand just in case. (I'm told 2-3 seasons is the lifespan) |
drew365 |
Aug 15 2006, 09:21 PM
You say the lexan windshield weighs 11#. How much does a stock one weigh?
brant |
Aug 15 2006, 09:23 PM
drew365 |
Aug 15 2006, 09:27 PM
You say the lexan windshield weighs 11#. How much does a stock one weigh? I actually don't know alot though somebody chime in or use the search feature I'm guessing 35-40lbs of High Center of Gravity weight. (probably 25lb savings?) Thats a good savings. Does the lexan get so scratched up that it's difficult to see out of? |
brant |
Aug 15 2006, 09:30 PM
[/quote]
Thats a good savings. Does the lexan get so scratched up that it's difficult to see out of? [/quote] yep... scratched.. starred, and stress cracked. mine is like a bad glass winshield at this point. on the other hand, I have seen Big 2inch rocks come flying at my face so bad that I flinched... they only left a star or scratch! so the safety factor is definitely there. my race shop had a teener that would hit 160 on the straight. the lexan would "flex" inward from the air pressure and make an audible "pop" noise... until you hit the brakes at the end of the straight and it "Popped" back out. the stuff is amazingly strong and safe. brant |
drew365 |
Aug 15 2006, 09:40 PM
160 in a tuna can on wheels. There's a story for the grandkids. (IMG:style_emoticons/default/biggrin.gif)
sww914 |
Aug 15 2006, 09:49 PM
Well, you're gonna die of something, might as well make a good story.
race914 |
Aug 17 2006, 08:02 AM
73 914-4 Group: Members Posts: 1,006 Joined: 31-October 05 From: Nipomo, California (Central Coast) Member No.: 5,027 Region Association: Central California |
kart54 |
Aug 18 2006, 01:09 PM
Senior Member Group: Members Posts: 544 Joined: 27-January 05 From: Ventura, California Member No.: 3,520 |
I don't recall the name but there is a guy out of Las Vegas selling used NASCAR windshields that fit into the 914 with a little bit of work. The name is in an old thread here from a year or two ago when I asked the same question. I bought one back then and it arrived in perfect condition. Cost was $55.00 plus shipping. Took a little cutting with a jigsaw and a fine blade to get it to fit the 914 but no big deal.
Most of the big nascar teams replace the windshields after every race even though they use tear-offs and the windshields are usually perfect (Must be nice to have that kind of money). If your using it as a track windshield make sure of the thickness. SCCA requires a minimum of 1/4" if I my memory serves me right. If you google "lexan windshield" I think you'll find it. Randy |
Lo-Fi Version | Time is now: 27th April 2024 - 11:21 AM |
