need to see a mounting bracket, 2L d-jet ECU to battery tray |
type47 |
Aug 17 2006, 10:42 AM
i need a pix of the mounting bracket that mounts the ECU to the battery tray for D-jet. i have the bracket that bends over the end and has the hole for the idle mixture adjust knob, but that bracket has 2 holes for screws that mount into the bracket (that i'm looking for a pix of) that looks like it attaches to the battery tray. there are a couple of pix in the factory workshop manual and the PET, but nothing good enough to recognize the bracket or dimensions to fab a bracket. the old engine is carbed and the replacement is FI. thanks. and if you have pix of the mounting on the other end of the ECU, i could use that too. i have a small bracket that is curved and has 2 slots which i think is for the second mounting screw holes.
many TIA Attached File(s) ECU_bracket.jpg.doc ( 189k ) Number of downloads: 133 |
Gary# |
Aug 17 2006, 11:03 AM
Member Group: Members Posts: 217 Joined: 15-May 05 From: Buena Park, Ca. Member No.: 4,078 |
Is this what your lookin' 4???
type47 |
Aug 17 2006, 11:16 AM
that's probably it. thanks. i don't remember that in my parts stash.
more pix appreciated from anyone. |
Gary# |
Aug 17 2006, 12:14 PM
davep |
Aug 17 2006, 02:22 PM
914 Historian Group: Benefactors Posts: 5,144 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
Each of the two pix shows half of the complete bracket set. Two parts with two bolts holding them together.
Bleyseng |
Aug 17 2006, 02:36 PM
How's this then for showing how the bracket/ECU mounts to the battery tray. (IMG:style_emoticons/default/thumb3d.gif)
type47 |
Aug 18 2006, 03:12 PM
excellent, thanks! i have the half that curves over the end of the ECU, but need the other piece. anyone have an extra?
Lo-Fi Version | Time is now: 21st May 2024 - 06:49 PM |
