What are these holes on the battery stand for? |
JeffBowlsby |
Aug 17 2006, 01:29 PM
914 Wiring Harnesses Group: Members Posts: 8,510 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Any ideas? (IMG:style_emoticons/default/confused24.gif)
Allan |
Aug 17 2006, 02:05 PM
On my '75 the MPS and Decel valve were mounted there.
Bleyseng |
Aug 17 2006, 02:14 PM
That would be a tough reach for the MPS wiring!
JeffB, its swisscheesing to lighten the car since its yellow! (IMG:style_emoticons/default/av-943.gif) |
JeffBowlsby |
Aug 17 2006, 02:15 PM
Not originally they weren't. They should be mounted to that triangular plate to the right of the photo.
I have always thought these holes were odd, because I have not seen a used for them...surely there is a factory requirement for them for something. Do any 914 battery stands not have them? |
Dads914 |
Aug 17 2006, 02:17 PM
Greg Group: Members Posts: 49 Joined: 21-June 06 From: So. Cal. Member No.: 6,277 |
On my '75 the MPS and Decel valve were mounted there. Mine are also mounted there. (IMG:style_emoticons/default/agree.gif) |
sportlicherFahrer |
Aug 17 2006, 02:21 PM
Nothing to see here. Group: Members Posts: 1,079 Joined: 18-April 05 From: Tacoma, WA Member No.: 3,945 Region Association: Pacific Northwest |
on the '75 1.8 I had, the resistor block and a couple FI relays were mounted there. Looked like there was no where else for those to go. I am pretty sure thats it.
Bleyseng |
Aug 17 2006, 02:24 PM
Well, this is a 70-74 car since the fuel pump mount is down below the battery tray. Maybe this is the holes for the Ljet relays as mentioned? All Djet cars I have seen had the MPS/decel valve mounted on the triangle plate. |
Bleyseng |
Aug 17 2006, 02:29 PM
original 76 engine setup showing the MPS/decel valve in the lower left corner
Attached thumbnail(s) |
magaoidh |
Aug 17 2006, 05:07 PM
Member Group: Members Posts: 187 Joined: 28-August 05 From: sydney,australia Member No.: 4,686 |
To stop the battery tray from rusting out????
So.Cal.914 |
Aug 17 2006, 05:11 PM
My 72 does not have them.
sixnotfour |
Aug 17 2006, 05:28 PM
914 Wizard Group: Members Posts: 10,432 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
QUOTE on the '75 1.8 I had, the resistor block and a couple FI relays were mounted there. Looked like there was no where else for those to go. I am pretty sure thats it. (IMG:style_emoticons/default/agree.gif) yup mine too |
TonyAKAVW |
Aug 17 2006, 06:18 PM
That's my ride. Group: Members Posts: 2,151 Joined: 17-January 03 From: Redondo Beach, CA Member No.: 166 Region Association: None |
My '70 does not have the holes, but it has some different ones...
This was from when I stripped down the paint in the engine bay recently. -Tony Attached image(s) |
ClayPerrine |
Aug 17 2006, 08:40 PM
Life's been good to me so far..... Group: Admin Posts: 15,465 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
That is where the L-Jet resistor block and double relay is mounted.
They were not on a 73 or older car, and any replacement battery tray support will have them. |
Porsche Rescue |
Aug 17 2006, 09:23 PM
Geoff, your pic shows the pipe I am trying to ID in another thread (76 2.0). The larger diameter silver pipe with the 90 degree turn, connecting to some device and then to hose, what is it? Also, the smaller silver on connected to the air cleaner is a mystery to me. The car I am looking at has a block-off plate where that tube meets the air cleaner in your pic. Educate me please.
RustyWa |
Aug 17 2006, 09:38 PM
Working Member Group: Members Posts: 610 Joined: 2-January 03 From: Kent, WA Member No.: 72 |
My '75 had the speed limiter thingy ma-bob attached to one of the holes using a screw. Looked stock.
Eric_Shea |
Aug 17 2006, 09:59 PM
Mine had a resistor block there...
sixnotfour |
Aug 17 2006, 10:20 PM
QUOTE Geoff, your pic shows the pipe I am trying to ID in another thread (76 2.0). The larger diameter silver pipe with the 90 degree turn, connecting to some device and then to hose, what is it? Also, the smaller silver on connected to the air cleaner is a mystery to me. The car I am looking at has a block-off plate where that tube meets the air cleaner in your pic. Educate me please. (IMG:style_emoticons/default/hijacked.gif) air pump check valve and egr stuff |
Bleyseng |
Aug 18 2006, 08:28 AM
EGR= Exhaust Gas Recirculation which takes some exhaust via the small pipe into the air cleaner. Now what the hell does that do?
Lo-Fi Version | Time is now: 17th May 2024 - 08:05 PM |
