JeffBowlsby
Aug 17 2006, 01:29 PM
Any ideas?
Allan
Aug 17 2006, 02:05 PM
On my '75 the MPS and Decel valve were mounted there.
Bleyseng
Aug 17 2006, 02:14 PM
That would be a tough reach for the MPS wiring!
JeffB, its swisscheesing to lighten the car since its yellow!
JeffBowlsby
Aug 17 2006, 02:15 PM
Not originally they weren't. They should be mounted to that triangular plate to the right of the photo.
I have always thought these holes were odd, because I have not seen a used for them...surely there is a factory requirement for them for something. Do any 914 battery stands not have them?
Dads914
Aug 17 2006, 02:17 PM
QUOTE(Headrage @ Aug 17 2006, 01:05 PM)
Mine are also mounted there.
sportlicherFahrer
Aug 17 2006, 02:21 PM
on the '75 1.8 I had, the resistor block and a couple FI relays were mounted there. Looked like there was no where else for those to go. I am pretty sure thats it.
Bleyseng
Aug 17 2006, 02:24 PM
QUOTE(Jeff Bowlsby @ Aug 17 2006, 12:29 PM)
Any ideas?
Well, this is a 70-74 car since the fuel pump mount is down below the battery tray. Maybe this is the holes for the Ljet relays as mentioned?
All Djet cars I have seen had the MPS/decel valve mounted on the triangle plate.
Bleyseng
Aug 17 2006, 02:29 PM
original 76 engine setup showing the MPS/decel valve in the lower left corner
magaoidh
Aug 17 2006, 05:07 PM
To stop the battery tray from rusting out????
So.Cal.914
Aug 17 2006, 05:11 PM
My 72 does not have them.
sixnotfour
Aug 17 2006, 05:28 PM
yup mine too
TonyAKAVW
Aug 17 2006, 06:18 PM
My '70 does not have the holes, but it has some different ones...
This was from when I stripped down the paint in the engine bay recently.
-Tony
ClayPerrine
Aug 17 2006, 08:40 PM
That is where the L-Jet resistor block and double relay is mounted.
They were not on a 73 or older car, and any replacement battery tray support will have them.
Porsche Rescue
Aug 17 2006, 09:23 PM
Geoff, your pic shows the pipe I am trying to ID in another thread (76 2.0). The larger diameter silver pipe with the 90 degree turn, connecting to some device and then to hose, what is it? Also, the smaller silver on connected to the air cleaner is a mystery to me. The car I am looking at has a block-off plate where that tube meets the air cleaner in your pic. Educate me please.
RustyWa
Aug 17 2006, 09:38 PM
My '75 had the speed limiter thingy ma-bob attached to one of the holes using a screw. Looked stock.
Eric_Shea
Aug 17 2006, 09:59 PM
Mine had a resistor block there...
sixnotfour
Aug 17 2006, 10:20 PM
air pump check valve and egr stuff
Bleyseng
Aug 18 2006, 08:28 AM
EGR= Exhaust Gas Recirculation which takes some exhaust via the small pipe into the air cleaner. Now what the hell does that do?
