Head Temps - How to get a temp reading?, 1.8L AMC heads |
ptravnic |
Aug 17 2006, 02:16 PM
Senior Member Group: Members Posts: 1,231 Joined: 27-May 03 From: Chicago, IL Member No.: 747 Region Association: None |
Oil Temps: I bought the thermometer dipstick to measure oil temps (not the perfect fix but it will work for now).
Cylinder Head Temps: How do I rig up a gauge to measure this? I'm running 96MM cylinders on 1.8L heads... What do I need to get a cockpit temp reading (other than the obvious temp guage) and how do I hook it up? I tried doing a search and came up empty. If this has already been covered (probably) then could someone point me to the thread? Thx in advance. -pt |
bd1308 |
Aug 17 2006, 02:18 PM
get the VDO kit. Even an idiot such as myself hooked it up.
It works without electricity. It's neat. but Red being ground needed some getting used to b |
ptravnic |
Aug 17 2006, 02:21 PM
get the VDO kit. Even an idiot such as myself hooked it up. It works without electricity. It's neat. but Red being ground needed some getting used to b Thx, which VDO kit and who sells it? Dumbass in need of directions... (IMG:style_emoticons/default/smile.gif) |
bd1308 |
Aug 17 2006, 02:23 PM
I'm a dumbass too (IMG:style_emoticons/default/smile.gif)
http://www.cip1.com they *USED* to be ~ $60 , but now are hovering around 100 for some reason. Guess the euro isnt what it used to be (or the dollar for that matter) b |
ptravnic |
Aug 17 2006, 02:27 PM
I'm a dumbass too (IMG:style_emoticons/default/smile.gif) http://www.cpi1.com they *USED* to be ~ $60 , but now are hovering around 100 for some reason. Guess the euro isnt what it used to be (or the dollar for that matter) b That link didn't work - game me a generic squatter's site... (IMG:style_emoticons/default/confused24.gif) |
MarkV |
bd1308 |
Aug 17 2006, 02:28 PM
mistype
cip1.com check edit. sorry. b |
sportlicherFahrer |
Aug 17 2006, 02:30 PM
Nothing to see here. Group: Members Posts: 1,079 Joined: 18-April 05 From: Tacoma, WA Member No.: 3,945 Region Association: Pacific Northwest |
what kinda of guage do you want to run? where are you putting it? Autometer 2 5/8 inch guages slip right into the factory center console holes with no mounting hardware needed.
ptravnic |
Aug 17 2006, 02:32 PM
No factory center console present on my 72. The gauge is not the issue - I can find just about any generic gauge that can read temperature. I'm confused as to how to wire it, what to wire it to, etc... Basically, a shcematic would do wonders...
-pt |
MarkV |
Aug 17 2006, 02:34 PM
ptravnic |
Aug 17 2006, 02:36 PM
MarkV - Now we're talking! Thanking U!
I'm taking the heads over to the shop in about 15mins to get them cc'd. I'll ask them about this as well. -pt |
lapuwali |
Aug 17 2006, 02:39 PM
You can get the VDO setup at aircooled.net, probably for cheaper than anywhere else. Also try CB Performance.
Wiring is very easy. The sensor has a ring end that slips around the spark plug, acting as another spark plug washer. Two wires off that, which lead to two terminals on the gauge. Run the wires up the center tunnel, either squishing them through the stock rubber harness cover, or just drill another hole. |
Aug 17 2006, 02:59 PM
Check that the sender fits nicely in the spark plug recess--the ones on my heave have a lip around it that cuts into the sender. (IMG:style_emoticons/default/sad.gif) The next time I have the tin off, I'll see if I can file or Dremel it flat in one spot.
--DD |
jd66921 |
Aug 17 2006, 03:01 PM
Member Group: Members Posts: 316 Joined: 9-January 06 From: Texas Member No.: 5,394 |
Speaking of CHT, which cylinder is the hottest under normal
circumstances? Which is the coolest? Thanks, Jeff |
bd1308 |
Aug 17 2006, 03:05 PM
#3 is hottest, unless you run lean. then #1 is usually the hottest.
when my engines died, they both ran djet and both of them had #1 die. b |
lapuwali |
Aug 17 2006, 03:18 PM
Because of the direction the fan turns, there's more airflow to the left bank of cylinders than the right bank. There's also (for obvious reasons) more cool air flowing to the front cylinders than the rear cylinders. So, the right-rear cylinder is the hottest running cylinder, and the left-front cylinder is the coolest running. There's usually as much as a 50dF temp difference between the hottest and coolest running cylinder with stock cooling.
ptravnic |
Aug 17 2006, 08:31 PM
Good info boys. I'm going to add a thermo when I put in my fresh heads next weekend.
Great feedback, exactly what I was looking for. -pt |
Lo-Fi Version | Time is now: 17th May 2024 - 07:10 PM |
