Electrical questions, What is a stock set up suppose to look like? |
poohsan |
Aug 19 2006, 09:05 PM
Newbie Group: Members Posts: 46 Joined: 10-July 06 From: Los Angeles Member No.: 6,409 |
I finally have some time to work on my 1975 1.8L. I’m working on the electrical first, as not all of it works. I’m hoping I can get some questions answered from you guys.
Thanks, Arron I’m not sure if the PO made any changes to the electrical. I’m also not sure what should be their as I have no reference point. I’m posting images of the Relay Board in the engine compartment and other places I have question about. Questions: 1. Is there anything missing from the board? I see open sockets. 2. Is this single wire supposes to be plugged into this socket? 3. The coil has been relocated to the fire wall. Where should it be located? 4. There are a lot of small wires coming from the top of the coil. Should there be so many wires and/or should they be relocated? |
So.Cal.914 |
Aug 19 2006, 09:39 PM
I don't see anything missing off hand, except maybe the cover. The coil wires
seem right but I will admit I have been wrong (1978 I think (IMG:style_emoticons/default/biggrin.gif) ). The coil goes on the engine tin (from back) right side front, there is a curved resess not far from where your coil is now. |
grasshopper |
Aug 19 2006, 10:02 PM
Advanced Member Group: Members Posts: 2,613 Joined: 10-December 04 From: Valdosta, GA Member No.: 3,258 Region Association: None |
The coil goes on the engine tin (from back) right side front, there is a curved resess not far from where your coil is now. I am pretty sure that it does not go on the engine tin for a 75 model year. I may be wrong though, but all of the 75-76 cars have had them mounted to the rear engine fan housing. Here is a picture. Anyway, everything looks right except where the coil is mounted. The missing plugs on your relay board are for the rear window defroster, which was optional. Attached image(s) |
So.Cal.914 |
Aug 19 2006, 10:43 PM
Told you I've been wrong.
Lo-Fi Version | Time is now: 17th May 2024 - 06:23 PM |
