TDI in a 914? |
TDI in a 914? |
914TD |
Aug 21 2006, 02:38 AM
Newbie Group: Members Posts: 7 Joined: 18-August 06 From: California Member No.: 6,680 |
Hi, newbie here.
Has anyone ever put an Audi or 1.9L VW TDI in a 914? Considering how well Audi did recently with their Turbo Diesel racecar it seems a natural. Any thoughts? I’m interested in trying it. Thanks. |
McMark |
Aug 21 2006, 03:10 AM
First thought is if the crank spins in the 'correct' direction. I haven't heard of anyone doing that swap. Most swaps have a lot of the same issues and a few unique ones, meaning that even if you're the first, you can get most of the way there with the help of the other 'swappers'. But at some point you'll be breaking new ground. (IMG:style_emoticons/default/wink.gif) Good luck!
Gustl |
Aug 21 2006, 03:26 AM
914 enthusiast & historian Group: Members Posts: 11,507 Joined: 16-June 04 From: TIROL / Austria Member No.: 2,212 Region Association: Austria |
first of all: (IMG:style_emoticons/default/welcome.png) - from far, far away (IMG:style_emoticons/default/biggrin.gif)
there was already a 1.9L TDI conversion try the search function - I remember about a thread to this topic, might be 2 years ago the only thing I still have in brain is, that he told us to make 55 mpg (IMG:style_emoticons/default/blink.gif) (IMG:style_emoticons/default/wavey.gif) Gustl |
Gustl |
Aug 21 2006, 03:32 AM
well, just found it - klick here
not much about the conversion, more about the fact ... (IMG:style_emoticons/default/wavey.gif) Gustl |
914TD |
Aug 21 2006, 05:32 AM
McMark,
Thanks, to the best of my knowledge all VW water-cooled engine crankshafts rotate in the same direction. For example: the inline 4, 2.0L 16Valve engine found in the GTI’s, some early Passats (90’-93’) and some special edition Jettas rotate in the same direction as the TDI engine. Doing a search it looks like the 2.0L 16V engine has been done as a 914 swap already, so I think I’m OK there. Gustl, Thanks for the link. The engine in the link you provided looks like a 1.9 TD (pre-95,) not a 1.9 TDI (95’-present.) It is a good link/start though as the engines have a lot of similarity and the engine mounts and bellhousing bolt patterns I believe are all the same, but the TD and the TDI aren’t the same animals. One important difference is that the TDI is drive by wire, is controlled by the ECU and can be chipped, the TD is mechanical, and modifications are more limited. I read the entire link you led me to and I get the impression that the first post with pictures of the swap comes from another site. If I’m right about that do you have any idea what site that came from? I’d like to try and get in touch with the builder of that beast. Tanks again for the reply(s) and the welcome mat. |
Gustl |
Aug 21 2006, 06:39 AM
yea, that's right
bitd board = www.pelicanparts.com you're absolutely correct about the TD vs. TDI thing I also thought, that if it's possible with the "good old 1.9 TD" it must be possible with the TDI - there might be a bigger problem with the larger air cooler of the TDI?? but I think it could be a cool swap, if you take a 1.9 TDI with VTG it should bring about 110 HP with big torque (IMG:style_emoticons/default/aktion035.gif) (the old TD engine has only 75 HP, IIRC on the other hand, the sound would be (IMG:style_emoticons/default/icon8.gif) (IMG:style_emoticons/default/wavey.gif) Gustl |
BMartin914 |
Aug 21 2006, 08:48 AM
||| Group: Members Posts: 1,408 Joined: 30-May 04 From: Oregon Member No.: 2,128 Region Association: Pacific Northwest |
QUOTE Thanks, to the best of my knowledge all VW water-cooled engine crankshafts rotate in the same direction. Which is? I know 77-84 NA 1.6L (and probably the 1.5s as well) Diesel Engines rotate clockwise. QUOTE It is a good link/start though as the engines have a lot of similarity and the engine mounts and bellhousing bolt patterns I believe are all the same, but the TD and the TDI aren’t the same animals. One important difference is that the TDI is drive by wire, is controlled by the ECU and can be chipped, the TD is mechanical, and modifications are more limited. Not necessarily, not if you know how to tune the diesel injection pump and use the LDA correctly. But you will also never get the power from a TD that will from a TDI in stock trim. |
mudfoot76 |
Aug 21 2006, 08:56 AM
Currently teenerless :-( Group: Members Posts: 946 Joined: 18-March 04 From: Carmel, IN Member No.: 1,814 Region Association: None |
but I think it could be a cool swap, if you take a 1.9 TDI with VTG it should bring about 110 HP with big torque (IMG:style_emoticons/default/aktion035.gif) (the old TD engine has only 75 HP, IIRC Sounds like an interesting project, and it could give us the start of a whole new debate: You can't propane-inject a 914 (IMG:style_emoticons/default/beer.gif) |
jonwatts |
Aug 21 2006, 09:08 AM
no rules, just wrong Group: Benefactors Posts: 2,321 Joined: 13-January 03 From: San Jose, CA Member No.: 141 |
A 914 stump puller, I like it (IMG:style_emoticons/default/smile.gif)
fiid |
Aug 21 2006, 09:11 AM
It would be awesome - someone should do it.
I've heard of Rabbit Diesel engine being put in a 914 as well.... that was a fairly winpy 1.6, but you could probably score one real cheap.... |
914TD |
Sep 18 2006, 04:03 AM
It would be awesome - someone should do it. I've heard of Rabbit Diesel engine being put in a 914 as well.... that was a fairly winpy 1.6, but you could probably score one real cheap.... Sorry for the lack of follow up, I’ve just been to busy. VW also made a 1.6 TD (only sold in Europe and Canada) which had a lot more spunk then the lazy old Rabbit NA 1.6 Diesel. I know because I own an 83 Jetta 1.6 TD that someone else imported a long time ago. I also own a 96’ Passat 1.9 TDI, and there is a world of difference between the old school and the new school VW diesels. The TDI is much more responsive and quieter too especially if run on Biodiesel, which is the only fuel I use and have for two years with great results and no problems, which led to this original post. The propane injection is a very real and solid idea, I haven’t tried it but know of a few people that have and it not only increases power but developes a much cleaner burn of the fuel, something worth considering. At the moment this project idea (at least for me for now)is in the future, but just remember how well Audi did in there recent victory races and it gets me thinking. |
hcdmueller |
Sep 18 2006, 11:01 AM
????????????? Group: Members Posts: 542 Joined: 4-February 06 From: UK Member No.: 5,527 Region Association: England |
I was looking at getting another 914 for a TDI swap. I was going to use the 2.5L V6 TDI from an A4 or A6. I don't think you can get those in the states though. I had an A4 rental with that engine and it absolutely flies. 140mph+ top speed, 40+ MPG and tons of torque. (IMG:style_emoticons/default/burnout.gif)
I just don't have the time though. Too many trips to unfriendly places. |
914fan |
Sep 18 2006, 11:33 AM
Member Group: Members Posts: 118 Joined: 17-January 05 From: Fountain Valley CA Member No.: 3,460 |
I have a 97 tdi and a 73 914. I also have thought about the tdi swap. It can be done. You will need to rework the tranny. The dti does not turn as high rpm as a gas motor. It realy only pulls to 4500. Also my tdi runs at about 3k (80 mph) That feels high. I would like it to be at 2k. Just an fyi.
It would run like a bat out of hell though with stock gearing. |
hcdmueller |
Sep 18 2006, 11:47 AM
If you are going to get into a TDI swap you might as well adapt one of the Audi 6 speed 2WD transmissions. It would be a great setup and you wouldn't have to worry about breaking 901's with all the torque.
Cap'n Krusty |
Sep 18 2006, 12:33 PM
Not all 4 cylinder VW TDIs are DBW. There were a few early yeas where they used conventional throttle cables. However, finding a used one that isn't DBW is getting tough. They've all been snapped up by conversion guys. DBW conversions require the instrument cluster and several other systems to come along in the transplant procedure. The Cap'n
grantsfo |
Sep 18 2006, 12:47 PM
Arrrrhhhh! Group: Members Posts: 4,327 Joined: 16-March 03 Member No.: 433 Region Association: None |
Subaru is supposed to have a flat 4 boxer turbo diesel ready to go in 2008. Now that would have some possibilities.
Here is a blurb on development: Subaru’s new turbodiesel engine would be modular, and will be introduced as a 2.2 liter 4 cylinder boxer, as well as a 3.3 liter 6 cylinder boxer. Since it is modular, technically a 4.4 liter 8 cylinder boxer could also be possible. It will be designed to be compatible with Subaru’s all-wheel drive technology. There is currently no turbodiesel engine using the boxer (horizontally opposed) cylinder configuration in the world, so Subaru’s will be the first. |
BMartin914 |
Sep 18 2006, 02:43 PM
Like Krusty said, you'd better hurry up because there are so many overly-optimistic people out there that hear free fuel and diesel engine and snap up anything they can find so they can coke up the motor with veggie oil because they don't have a clue - just like the "make free diesel" guys on craigslist - you didn't think it was really that easy did you.
My 1.6 NA Rabbit PU does pretty good for 52 screaming horses (probably about 80 lb/ft of torque) and the rabbit body doesn't weigh that much more than the 914 (it might even weigh less). It isn't as underpowered as it seems and it is all mechanical (except for the fuel stop solenoid) so when the aliens come, you'll be prepared. :(IMG:style_emoticons/default/biggrin.gif): |
rich brennick |
Sep 18 2006, 05:44 PM
Forever Newbie Group: Members Posts: 76 Joined: 23-July 03 From: Mid-Michigan Member No.: 942 |
Quite a little "cult" following of making big boost/ big fueling/ big power with both the 1.6 TD as well as the 1.9 TDI; lots of enthusiasts dump the electronics and go with mechanical pumps for tuning on the TDI platforms.
The GTD forum: http://www.vwdiesel.net/phpBB/index.php?si...4c49ffa4b13e56a I have both NA VW diesels and 1.6 TD vehicles (5 at last count); bomb-proof reliable with great mileage. Not as quick as my V8 914, though (IMG:style_emoticons/default/biggrin.gif) As we are now in a oil pricing "lull," I hope we as a country do not forget how quickly our family budgets can go south due to fuel cost. A 914 turbo-diesel sounds like an appropriate project! Good Luck! And here's a pic of that LeMans-winning V12 TDI diesel: Attached image(s) |
BMartin914 |
Sep 18 2006, 06:36 PM
QUOTE I have both NA VW diesels and 1.6 TD vehicles (5 at last count); bomb-proof reliable with great mileage. Had any experience with blowby runaway? And here's a pic of that LeMans-winning V12 TDI diesel: Got wood? (IMG:style_emoticons/default/wub.gif) |
MecGen |
Sep 18 2006, 07:37 PM
8 Easy Steps Group: Members Posts: 848 Joined: 8-January 05 From: Laval, Canada Member No.: 3,421 |
Hey
I think its a great idea, as said at the start of the thred, you gonna have to do a lot of engineering. I am realy interested in whats involved with the dash? is it an immo thing? guys in Europe been dissabling them for years, I suspect some of the inputs are coming thru the cluster...and converted...thats gonna be tough. Food for thought Later (IMG:style_emoticons/default/beerchug.gif) |
Lo-Fi Version | Time is now: 21st May 2024 - 07:38 AM |
