Thought about it myself, but I drive my 914 for fun, I drive my TDI cause I need to. the TDI makes a great long haul car. Problem with the 901, nobody makes a gear that would make it okay for a highway cruise. This topic has been on this board before. I would love to have a taller fith in my TDI right now, I run 3000 @ 90, btw, mine will spin faster and make power above the 4500 stock drop off. But the problems you have is the 914 /901 combo. It is wrong, so another bullit proof tranny has to be had. Audi makes several, VW Passat comes to mind on the Audi chassis, engine tranny runs the correct way, 2WD are plentyfull. The early models are good for a swap, not DBW, but they cake the intake pretty severly.
Cooling is not a problem, my engine will get cold sitting in traffic, only time it needs air flow is when you are moving. That is easy. Intercooling is another issue, you will have to deal with if using a TDI, though one larger than stock is not necesary.
A good chip, larger injectors, good soot management, and a free flowing exhaust. You will also want a tranny with a limited slip, unless you like toasting one wheel in 3 gears.
Most people are amazed at what I can do in my TDI, most don't believe it runs on bio, I don't do the veg thing. Most can not believe I auto-x the car and keep up with the gas boys, and best of all they fall on there faces when I pull up the mileage figures at the auto-x and I am still getting way above 42 mpg (combinded city / highway/auto-x), even driven the piss out of it.
Now the downsides, maintance - most say it is less than a gas car, I really think it is close to the same. These engines like oil - it needs to be keep clean. The eat gaskets, and vibrate stuff loose all the time, so you got to stay after that. they can leak oil like nobodies business, and it is messy to clean up. Part of the vibration thing. And they eat timing belts, so replace them before the recommeded time frame. Or big $$$$ repairs ( ask me how I know
It is not hard to do, you have to get the proper tools. If you advance the fuel timing a little bit your engine will rev a little higher, also, run more efficant. Thats about all there is to them. Mine is getting close to 250,000 miles. Hopeing it will go another 750,000. Would I do one in a 914 probally not, would a do one for a daily driver yes in another car.
My ultimite daily would be a VW Corrado with a TDI, and AWD swaped into it. Still waiting on VW and Audi to get with the program and import the AWD diesels into our market. Read a thing the other day that Ford was suprised that the AWD 500 was selling 60% above expectations.
Freakin Morons!!!!
