wrench size question... HELP |
VaccaRabite |
Aug 25 2006, 01:58 PM
En Garde! Group: Admin Posts: 13,444 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
So, I am taking off the rear suspension bits. What size is the bolt that connect the shock to the rear control arm. Also, what size are the two bolts (or bolt / nut) that connect the control arm to the body of the car?
I have metric wrences up to 17mm, and these are bigger then then that. Haynes did not have the size when I looked. So beofre I go out and spend money on large meteric wrenches that I may never use, I thought I'd ask here. my car is a 76, if that makes any difference. Thanks Zach |
Lo-Fi Version | Time is now: 19th May 2024 - 01:45 AM |
