Thinking of selling the teener, 3 years of domination is enough... |
porsche735 |
Oct 24 2003, 06:14 PM
Member Group: Members Posts: 189 Joined: 10-January 03 From: Los Altos, CA Member No.: 127 |
So, after running in the BP class for going on 7 years with the same car, I think it is time to move on. We are about 5 seconds faster in this car than our next nearest competitior and we want to move to some competition. If I am going to race against my dad, I can do it in another class just as easily....
Here are the car's stats: 1973 914 2.0L Buttonwillow track record (within 1 second of track record at Thunderhill (both directions) and Laguna Seca on Kumho Victoracers!!!) 4 1st place seasons 2 2nd place seasons http://www.pca-ggr.org/ttresults.html We just finished rebuilding the engine and installing a "real" front mounted oil cooler. General car info: Rust Free Fresh rebuild with everything "done right" All internals balanced, head cc'ed, oil galleys ported, high volume oil pump, oil plugs threaded, heads reworked with oversized valve seats and new sodium filled valves/guides. No oil leaks. Kerry Hunter Headers with both Supertrapp and "Laguna Seca muffler" setup Bored throttle body Modified air intake Rebuilt dizzy and new vaccum canister Bowlsby FI harness Fresh clutch Fresh synchros in trans New 1st gear slider and reverse idler in trans New shift linkage bushings including bronze rear Braided brake hoses Brake proportioning valve Rebuilt calipers (3 years) Porterfield Brakes (with extra set F/R) Custom front airdam with brake cooling hoses Rebuilt/bronze bushed pedal cluster with new throttle pedal Short shift kit with sprung centering Custom front oil cooler with AN-12 lines and thermostat Moved fuel pump to front Plastic suspension bushings Chassis stiffening kit (done right) Inner suspension mount stiffening to fire wall Rear 180 lb springs Front 23 mm hollow torsion bars Front 23 mm Weltmeister adjustable drop link sway bar Turbo tie rods and rack spacer Momo steering wheel and shift knob Roll bar Harness bar 2 sets of 5 point harnesses (1 new) External engine cutoff switch Custom flared fenders New front windshield Corner balanced and race aligned 15x6 Panasports with Victoracers (1 event) Other spare parts....fuel pump, throttle/clutch cables, etc. I also have a "new" re-geared transmission and another set of Panos (with lovely corded rubber on them) selling separately... What do you think I should ask? I will be putting on eBay soon.... Chris Attached image(s) |
ArtechnikA |
Oct 24 2003, 06:23 PM
it'll be interesting to see...
"everybody" says the thing to do when talking about building up a car like this is "buy one that's already done." be interesting to see how many people take their own advice and come though with the cash. Mark Litherland GA was selling an approximately comparable car a while ago, i think he wanted about $8500 but i don't think it ever sold. one disadvantage of buying a class-winning car is that if the new owner isn't fast out of the box, s/he has nothing to blame it on! good luck with it - i'm not in the market tho ... |
ChrisReale |
Dude, you know the outcome....you wont get what you put in it, and some jack off will try to low ball you. That said, Id guess $6 to $8K maybe? Im not sure because it is a racer, and the market for those is so much smaller than for streetable 914's. I recognize the value in all you have done, but unfortunatly most others wont.... (IMG:style_emoticons/default/sad.gif)
porsche735 |
Oct 24 2003, 06:31 PM
It is street legal...... Yes, we have added how much we have put into it over the years and I will be lucky to get some portion of that. What I really want to do is sell it and get a 1972/3 911S and do a ground up...
Chris |
Mueller |
Oct 24 2003, 06:33 PM
I think in the $10k+ range, it's a fully sorted out car, it would make a fun street car, but you better like that paint job (IMG:style_emoticons/default/smile.gif)
Good luck Chris |
jonwatts |
Oct 24 2003, 11:23 PM
no rules, just wrong Group: Benefactors Posts: 2,321 Joined: 13-January 03 From: San Jose, CA Member No.: 141 |
QUOTE(ChrisReale @ Oct 24 2003, 04:23 PM) Dude, you know the outcome....you wont get what you put in it, and some jack off will try to low ball you. Hey, can't we at least low ball him before you call us jack-offs? (IMG:style_emoticons/default/smile.gif) You'd probably do better to part it out but that takes longer than most people want to deal with. It's much nicer to just see the car drive away with you holding the cash. Personally, if I'm ready to get rid of something I go towards the low end of realistic pricing; it's better than sitting on something for 8 months waiting for that one guy with $10k to show up. Are you sure you want to put in on Ebay? Who knows how many times you'd have to re-list it before a "real" buyer shows up. Oh, and if you want to stay competetive, don't put so much money into the 911. You and your dad are good drivers, no need to overcompensate with hardware (IMG:style_emoticons/default/laugh.gif) |
redshift |
Oct 24 2003, 11:30 PM
QUOTE(jonwatts @ Oct 25 2003, 01:23 AM) Hey, can't we at least low ball him before you call us jack-offs? (IMG:style_emoticons/default/smile.gif) (IMG:style_emoticons/default/smilie_pokal.gif) M |
Brad Roberts |
Oct 24 2003, 11:53 PM
Put it on Ebay. If it doesnt sell the third time... part it out and junk the chassis.
B |
brant |
Oct 25 2003, 01:40 PM
914 Wizard Group: Members Posts: 11,622 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
A couple of -4 race cars have listed on ebay lately and gone pretty cheaply.
A guy I know named David in Kansas has a similar car to you with 5 bolts on it and a fairly fresh motor... He is asking 10K and has been holding out for 15months now. I've seen 3 local cars that were also similar bring their price down about 3000 before they sold.. started around 11k. Its shitty that there just is not a market for production class or street based 914 race cars. A clean street car will go for about 1200 less than a race car like yours that has an extra 8000 invested in it. I'm not trying to come off as negative. I was in your postition last year... trying to decide what to do with my -4 race car. I came to the realization that I would probably only get 8500 for it even though (like yours) I had spent a ton more than that. Being the cheapskate that I am. I sold off all of the race parts for a higher percentage of what they cost and am building it back into a street car. As a street car it will probably only sell for the 1500 difference than it would have as a race car, and I sold off 4K worth of motor and race parts to cover my labor. $.02 brant |
porsche735 |
Oct 27 2003, 06:35 PM
I'll take some pictures of the pertinent parts and post them this weekend. If I don't get any takes here (an on the Classifieds), it's evilBay...
Chris |
Lo-Fi Version | Time is now: 8th May 2024 - 09:09 AM |
