So, after running in the BP class for going on 7 years with the same car, I think it is time to move on. We are about 5 seconds faster in this car than our next nearest competitior and we want to move to some competition. If I am going to race against my dad, I can do it in another class just as easily....
Here are the car's stats:
1973 914 2.0L
Buttonwillow track record
(within 1 second of track record at Thunderhill (both directions) and Laguna Seca on Kumho Victoracers!!!)
4 1st place seasons
2 2nd place seasons
http://www.pca-ggr.org/ttresults.html
We just finished rebuilding the engine and installing a "real" front mounted oil cooler.
General car info:
Rust Free
Fresh rebuild with everything "done right"
All internals balanced, head cc'ed, oil galleys ported, high volume oil pump, oil plugs threaded, heads reworked with oversized valve seats and new sodium filled valves/guides. No oil leaks.
Kerry Hunter Headers with both Supertrapp and "Laguna Seca muffler" setup
Bored throttle body
Modified air intake
Rebuilt dizzy and new vaccum canister
Bowlsby FI harness
Fresh clutch
Fresh synchros in trans
New 1st gear slider and reverse idler in trans
New shift linkage bushings including bronze rear
Braided brake hoses
Brake proportioning valve
Rebuilt calipers (3 years)
Porterfield Brakes (with extra set F/R)
Custom front airdam with brake cooling hoses
Rebuilt/bronze bushed pedal cluster with new throttle pedal
Short shift kit with sprung centering
Custom front oil cooler with AN-12 lines and thermostat
Moved fuel pump to front
Plastic suspension bushings
Chassis stiffening kit (done right)
Inner suspension mount stiffening to fire wall
Rear 180 lb springs
Front 23 mm hollow torsion bars
Front 23 mm Weltmeister adjustable drop link sway bar
Turbo tie rods and rack spacer
Momo steering wheel and shift knob
Roll bar
Harness bar
2 sets of 5 point harnesses (1 new)
External engine cutoff switch
Custom flared fenders
New front windshield
Corner balanced and race aligned
15x6 Panasports with Victoracers (1 event)
Other spare parts....fuel pump, throttle/clutch cables, etc.
I also have a "new" re-geared transmission and another set of Panos (with lovely corded rubber on them) selling separately...
What do you think I should ask? I will be putting on eBay soon....
Chris
