/6 Conversion Throttle Set-up, Please show me what you have. |
Allan |
Sep 1 2006, 03:11 PM
I just got done replacing my clutch cable and started to see if I could adjust my throttle so I could get the carbs to fully open.
I have a bell crank that mounts to the right side of the tranny and just doesn't seem right. The way the cable is routed to it, makes 3 or 4 really tight bends and leaves it touching the top of the cv joint. What are you guys using for throttle set-up with carbs? Pics would be very, very goooood.... |
john rogers |
Sep 3 2006, 02:57 PM
Senior Member Group: Members Posts: 1,525 Joined: 4-March 03 From: Chula Vista CA Member No.: 391 |
Sure are a lot of parts to bind and/or come loose in those bellcrank setups. I use a cable from a four and have a small aluminum abgle bracket mounted on top of the bell housing. Full throttle is no problem and very simple.
Lo-Fi Version | Time is now: 8th June 2024 - 07:12 PM |
