18 wheel fitment question |
Wide914 |
Sep 3 2006, 06:35 PM
Newbie Group: Members Posts: 25 Joined: 24-April 06 From: Toronto, On - Vancouver, BC Member No.: 5,917 Region Association: None |
I have a 914 with steel gt fenders, i want to put a pair of 18in techarts on it fronts are 7.5 width with 42 offset and the rears are 9.5 width with 47 offset. i set the rears under the car and they seemed to fit into the fender if i was to get a 1inch spacer.. am i crazy or will these be able to stuff inside them seems like it works but some say they are to wide???
what would you guys say.. thanks. JP |
Sep 3 2006, 07:06 PM
I have a 914 with steel gt fenders, i want to put a pair of 18in techarts on it fronts are 7.5 width with 42 offset and the rears are 9.5 width with 47 offset. i set the rears under the car and they seemed to fit into the fender if i was to get a 1inch spacer.. am i crazy or will these be able to stuff inside them seems like it works but some say they are to wide??? i don't see a problem with the 7.5 in the front, but the 9.5 in the rear will be *tight*, especially in 18" height ... they may fit in there dry, but you gotta think about the camber change when you hit a bump in the road, the wheel will need some inside AND outside space to be able to move on load/lift. use the tire size calculator to see how much you're off in height from a stock wheel ... http://www.914world.com/specs/tirecalc.php (IMG:style_emoticons/default/smile.gif) Andy |
Wide914 |
Sep 4 2006, 10:31 AM
I have a 914 with steel gt fenders, i want to put a pair of 18in techarts on it fronts are 7.5 width with 42 offset and the rears are 9.5 width with 47 offset. i set the rears under the car and they seemed to fit into the fender if i was to get a 1inch spacer.. am i crazy or will these be able to stuff inside them seems like it works but some say they are to wide??? i don't see a problem with the 7.5 in the front, but the 9.5 in the rear will be *tight*, especially in 18" height ... they may fit in there dry, but you gotta think about the camber change when you hit a bump in the road, the wheel will need some inside AND outside space to be able to move on load/lift. use the tire size calculator to see how much you're off in height from a stock wheel ... http://www.914world.com/specs/tirecalc.php (IMG:style_emoticons/default/smile.gif) Andy Thanks for the reply Andy thats a good point about the camber change that had crossed my mind, i will do some more calculations thanks for the link JP |
Lo-Fi Version | Time is now: 15th May 2024 - 04:27 AM |
