noob - engine mount bar choice?, which bar to use? |
Jax914 |
Sep 3 2006, 09:02 PM
Schwienhund Rennenmannshaft Group: Members Posts: 138 Joined: 7-August 06 From: Jacksonville, FL Member No.: 6,602 Region Association: South East States |
My car was a puzzle when I got it...fortunately I got a "complete" parts car so I've had something to use as a guide.
But I have two different styles of engine cross bar. One with the hole and one without... I have a 1.7 and a tail shift tranny. Which one should I spend the time cleaning up and painting without having to go through a full engine install? (IMG:http://i35.photobucket.com/albums/d182/PunchBug71/engine_mount.jpg) Thanks, Troy (IMG:style_emoticons/default/welder.gif) |
John |
Sep 3 2006, 09:03 PM
Tail shift = top
Side Shift = bottom |
Jax914 |
Sep 3 2006, 09:04 PM
Thanks! This is the fastest board I've ever seen for answers.
Aaron Cox |
Sep 3 2006, 09:05 PM
i concur with john....
transmission dictates which to use |
davep |
Sep 3 2006, 09:19 PM
914 Historian Group: Benefactors Posts: 5,141 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
Well sort of. Yes the tranny will dictate quite a bit. However you have to do a bit of extra work if you use a late tranny in an early car. Up to end of 72 the early bar was used with the tailshift and the approriate linkage. That linkage, especially when it exits the firewall is a lot different from that used in 1973.
Cap'n Krusty |
Sep 4 2006, 12:36 AM
My car was a puzzle when I got it...fortunately I got a "complete" parts car so I've had something to use as a guide. But I have two different styles of engine cross bar. One with the hole and one without... I have a 1.7 and a tail shift tranny. Which one should I spend the time cleaning up and painting without having to go through a full engine install? (IMG:http://i35.photobucket.com/albums/d182/PunchBug71/engine_mount.jpg) Thanks, Troy (IMG:style_emoticons/default/welder.gif) Those 2 rubber mounts you have with the early mount (top) belong with the later mount (bottom). You CANNOT use them with a tail shift tranny. Not also that the parts bolted directly to the engine differ as well. You cannot use the late brackets with the early bar, nor can you use the parts bolted to the body. The early cars use mounts there, the late cars use brackets. The Cap'n |
nbscooters |
Sep 4 2006, 02:21 AM
Member Group: Members Posts: 165 Joined: 29-June 05 Member No.: 4,347 Region Association: None |
cars prior to 1972 came with that mount. the motor mounts for the top of motor mounts can cost over 100 bucks per rubber mount. i would suggest the sideshift with lower motor mount.
Lo-Fi Version | Time is now: 14th May 2024 - 12:39 AM |
