QUOTE(Jax914 @ Sep 3 2006, 08:02 PM)
My car was a puzzle when I got it...fortunately I got a "complete" parts car so I've had something to use as a guide.
But I have two different styles of engine cross bar. One with the hole and one without... I have a 1.7 and a tail shift tranny. Which one should I spend the time cleaning up and painting without having to go through a full engine install?
Thanks,
Troy
Those 2 rubber mounts you have with the early mount (top) belong with the later mount (bottom). You CANNOT use them with a tail shift tranny. Not also that the parts bolted directly to the engine differ as well. You cannot use the late brackets with the early bar, nor can you use the parts bolted to the body. The early cars use mounts there, the late cars use brackets. The Cap'n
