motor mount ? for converting to sideshift |
Bill Smith |
Sep 4 2006, 06:42 AM
Member Group: Members Posts: 169 Joined: 2-May 06 From: Keyser, WV Member No.: 5,964 |
Did I do it right? (IMG:style_emoticons/default/WTF.gif)
I have a 71 that I converted to a sideshift - My guestion is motor mounts - When I converted to the side shift front bar - I kept the 71 front motor mount but the hole didnt line up with the shift bar. I took them off and bolts the front bar straight to the car - metat to metal. I kept the rear the same as the 71. |
JoeSharp |
Sep 4 2006, 07:08 AM
In Irvine, Ca. May 15-18 Group: Members Posts: 3,947 Joined: 9-July 03 From: DeLand, Florida Member No.: 898 Region Association: South East States |
The rubber mount on the SS is at the bracket to the engine and on the TS it's on the end of the engine bar.
Do you have 2 of these? Joe |
alpha434 |
Sep 4 2006, 07:23 AM
My member number is no coincidence. Group: Members Posts: 3,154 Joined: 16-December 05 From: Denver, CO Member No.: 5,280 Region Association: Rocky Mountains |
There's a noob around here who's got both an early and a late motor mount. He only needs the tail shifter. You might be able to use that side shift mount.
SLITS |
Sep 4 2006, 08:44 AM
What Joe pictured is the body end mounts on the engine bar. They replace the rubber mount on the early cars (yeh, solid to the body).
If you are talking about the motor mounts themselves, the early style won't work. The late engine mounts are two seperate pieces of metal that bolt to the case (they are right and left hand). Attached to them are the rubber donuts that go between the case mount and engine bar. Sorry, no pics. |
Lo-Fi Version | Time is now: 15th May 2024 - 07:52 PM |
