head temp sensor D-jet |
shaggy |
Sep 5 2006, 06:35 PM
mechanic/welder/fabricator Group: Members Posts: 702 Joined: 26-September 05 From: Gilbert, AZ Member No.: 4,869 Region Association: None |
im putting together a 73 engine running stock d-jet (i dont know the year)
i dont have a head temp sensor pelican has 2 one for all models but the 73 2.0 and one for the 73 2.0 my question is does the temp sensor need to fit the heads or the FI system? i.e. does the sensor vary depending on the year of the FI system or the head which the sensor is going to be installed in? -shaggy |
Bartlett 914 |
Sep 5 2006, 06:42 PM
I had this problem. Do not mix the sensors from 73 to 74. There was a big difference. The 73 needs to have a balast resistor in series and the correct ECu and MPS. The 74 uses no ballast resistor. Check with Anders guide. There is a chart showing the correct mix.
Mark |
Cap'n Krusty |
You need 311 906 041A (0 280 130 003). BE SURE you get a NEW copper washer of the correct size. The Cap'n
shaggy |
Sep 5 2006, 06:47 PM
Cylinder Head Temp Sensor, 914, All Except 1973 2.0 (1970-76), Each 311-906-041-A-M14
/\ that one? the other is: Cylinder Head Temp Sensor, 914 2.0 (1973), Each 022-906-041-A-OEM thanks -shag |
Bartlett 914 |
Sep 5 2006, 08:12 PM
I see the confusion. The first one sounds wrong. Check with Paul Anders site
http://members.rennlist/pbanders/ He shows 0280 130 003 for the 1973 1.7 2.0 0280 130 012 for the 1974 2.0 AZautohouse.com has them (at least on their site). I did get one from them a year ago. Mark |
Sep 5 2006, 08:34 PM
914 Idiot Group: Members Posts: 14,991 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
The sensor goes with the rest of the EFI, not the engine. If the MPS and ECU are 73, then get the 73 version of the HTS. And the resistor--I think it's 240 ohms?
--DD |
shaggy |
Sep 5 2006, 08:36 PM
thanks dave!
thanks all! now all i have to do is figure out what year FI i have.. -jim |
mightyohm |
Sep 5 2006, 11:45 PM
shaggy, check out the part # on the ECU box and look at Brad Anders FI list. That should tell you what year it is. There are other clues too, for example if the FI came with a dizzy and it has the advance port plugged, it is most likely from a 74 2.0. You should be able to piece together what you have by writing down the part #s and comparing them to Brad's list.
PS: I agree with Dave, you match the head sensor to the FI. |
BMartin914 |
Sep 6 2006, 11:53 AM
||| Group: Members Posts: 1,408 Joined: 30-May 04 From: Oregon Member No.: 2,128 Region Association: Pacific Northwest |
You need to ensure that your ECU, MPS and TS2 (head temp sensor) are all the correct part #s for *a* d-jet setup. It doesn't really matter if you ran '74 components on the '73 engine, just don't run a 73 ECU and MPS with a 74 TS2.
As mentioned, Brad Anders' site lists the part # for the specific years. |
pbanders |
Sep 6 2006, 05:50 PM
Senior Member Group: Members Posts: 939 Joined: 11-June 03 From: Phoenix, AZ Member No.: 805 |
I see the confusion. The first one sounds wrong. Check with Paul Anders site http://members.rennlist/pbanders/ He shows 0280 130 003 for the 1973 1.7 2.0 0280 130 012 for the 1974 2.0 AZautohouse.com has them (at least on their site). I did get one from them a year ago. Mark Slight correction, the URL is: http://members.rennlist.com/pbanders |
Bartlett 914 |
Sep 6 2006, 07:47 PM
I see the confusion. The first one sounds wrong. Check with Paul Anders site http://members.rennlist/pbanders/ He shows 0280 130 003 for the 1973 1.7 2.0 0280 130 012 for the 1974 2.0 AZautohouse.com has them (at least on their site). I did get one from them a year ago. Mark Slight correction, the URL is: http://members.rennlist.com/pbanders Thanks for the correction. and BTW, thanks for the great resource you have provided for us to use. I cannot begin to tell you how much it helped me understand this setup. Thanks again. Mark |
BMartin914 |
Sep 6 2006, 09:51 PM
I see the confusion. The first one sounds wrong. Check with Paul Anders site http://members.rennlist/pbanders/ He shows 0280 130 003 for the 1973 1.7 2.0 0280 130 012 for the 1974 2.0 AZautohouse.com has them (at least on their site). I did get one from them a year ago. Mark Slight correction, the URL is: http://members.rennlist.com/pbanders Thanks for the correction. and BTW, thanks for the great resource you have provided for us to use. I cannot begin to tell you how much it helped me understand this setup. Thanks again. Mark (IMG:style_emoticons/default/agree.gif) It is The Bible for D-Jet owners. |
Lo-Fi Version | Time is now: 3rd June 2024 - 06:33 PM |
