unusual 914, built for drag racing |
jimkelly |
Sep 6 2006, 09:00 PM
Delaware USA Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region |
by a buddy of mine
Rider914 |
Sep 6 2006, 09:02 PM
Member Group: Members Posts: 276 Joined: 13-April 04 From: Palm Beach Member No.: 1,923 |
Cool, give us the specs and more pictures!
Mueller |
Sep 6 2006, 09:12 PM
I'm guessing that big box is the transfer case?!?!?!?
that is one way to avoid having to have an expensive 930 gear box (IMG:style_emoticons/default/blink.gif) |
alpha434 |
Sep 6 2006, 09:15 PM
My member number is no coincidence. Group: Members Posts: 3,154 Joined: 16-December 05 From: Denver, CO Member No.: 5,280 Region Association: Rocky Mountains |
Argh!!!! Strait axles!!!!! Eck!
IronHillRestorations |
Sep 6 2006, 09:21 PM
jimkelly |
Sep 6 2006, 09:26 PM
more pics ...
http://www.pbase.com/jimkelly/glenns_914 Criticism welcome - with explanation more welcome : ) Tomorrow night he puts his efforts to the test on the Sumerduck Dragstrip in VA. Jim |
Aaron Cox |
Sep 6 2006, 09:41 PM
ok... the dual diff thing is stupid scary......
welded diffs or they wouldnt spin.. |
nebreitling |
Sep 6 2006, 09:46 PM
that is.... strange. very cool, what it type of times is it expected to run?
Brian Mifsud |
Sep 6 2006, 09:47 PM
Mechanical Engineer Group: Members Posts: 981 Joined: 3-March 03 From: Penngrove, CA Member No.: 384 Region Association: None |
TWIN PUMPKINS!!!!!!!!!!!!!?????????? your buddy needs a hospital......
ultimate hillbilly transaxle... this wins the prize.... Stand way back when the shrapnel starts to fly.............. |
jimkelly |
Sep 6 2006, 09:54 PM
all I know is he was winning races with his custom 901 tranny but got tired of being taken off the line - so this effort is primarily to improve 0-60 foot times -as I understand it.
rick 918-S |
Sep 6 2006, 10:22 PM
Hey nice rack! -Celette Group: Members Posts: 20,460 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
I've studied the photos for about ten minutes. I don't understand how the suspension works. The 4 link is standard drag race issue, but connected to the transfer box that is connected in the center to the transmission that doesn't move? That transmission is going to explode when he dumps it.
bondo |
Sep 6 2006, 10:34 PM
Wow. More proof that anything can be done if you're persistent. Wasn't there someone on here a while back wanting to put a powerglide in his V8 914 that described something like this?
I'm thinking the life of that chain is going to be limited. (IMG:style_emoticons/default/burnout.gif) Edit: Found it. Sounds like the same car. |
Boojum |
Sep 7 2006, 12:17 AM
Member Group: Members Posts: 95 Joined: 31-July 06 From: Denver, CO Member No.: 6,550 |
Wow. More proof that anything can be done if you're persistent. Wasn't there someone on here a while back wanting to put a powerglide in his V8 914 that described something like this? I'm thinking the life of that chain is going to be limited. (IMG:style_emoticons/default/burnout.gif) Edit: Found it. Sounds like the same car. Yeah, not only that, but even if it dosen't immediately self-destruct, all that mechanical hubbly jubbly will just serve to rob power and add weight. But it's pretty creative, though, gotta admit. |
jimkelly |
Sep 7 2006, 06:49 AM
I asked my buddy how he mounted is engine and transfer case - this is his reply.
"They are both solid mounted. The connection between the transfer and transmission will allow radial movement to allow for flex that might occur in the chassis due to engine torque. There is no provision for longitudinal movement. I hope I don't have any movement in this plane. Will find out tonight. GP" |
Mike T |
Sep 7 2006, 07:31 AM
can't 'member Group: Members Posts: 378 Joined: 16-January 03 From: Brackney, PA Member No.: 161 |
The rear suspension is a DeDion design. See the "upside down vee" looking rectangular tube structure? That connects the 2 (!) differentials together. It will act like a live axle that just arches up over the transmission. It also has a 4-bar drag car trailing arm setup and a Panhard bar to control lateral movement. It's an OK design except for the fierce amount of unsprung weight. Looks like enough room for a short driveshaft between each differential and the transfer case.
Mike T |
jimkelly |
Sep 7 2006, 07:35 AM
yes - that is correct - a short drive shaft runs from each side of the transfer case to each pumpkin.
Kerrys914 |
Sep 7 2006, 08:45 AM
Have him bring that to the ECC on the 16th.. That would be cool to see (IMG:style_emoticons/default/smile.gif)
URY914 |
Sep 7 2006, 09:14 AM
I built the lightest 914 in the history of mankind. Group: Members Posts: 120,614 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
Being that the forces are different in drag racing than road racing, I don't know if he needs more tubing or not, but I'd add some diagonal bracing anyway.
andys |
Sep 7 2006, 09:41 AM
Here's one I thought I'd share with you. This guy is putting 1000HP through this setup.
Andys Attached File(s) 1000HP_Trans.doc ( 242.5k ) Number of downloads: 167 |
Mike T |
Sep 7 2006, 11:59 AM
Cool. What is that going in?
I saw a similar lighter duty version of that in a Kitcar called a Zara about 10 yrs ago. I'll see if I can get the pics scanned and add them here. Mike T |
Lo-Fi Version | Time is now: 17th May 2024 - 06:47 AM |
