Imminent Cam failure?, Strange wear on the lobes (pictures) |
Mueller |
Oct 27 2003, 11:42 AM
see the pattern on the lobes...
Is the cam failing or the lifters?? It looks like the metal was "pushed" in order to make the impression???? or is this normal?? Attached image(s) |
Brad Roberts |
Oct 27 2003, 11:43 AM
Normal. Not good.. but normal.
I'll bring you a cam. B |
914werke |
Oct 27 2003, 11:50 AM
"I got blisters on me fingers" Group: Members Posts: 10,050 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
Mike, how old is the combo that came from. I have a couple of 100K cams that look like that. (IMG:style_emoticons/default/ohmy.gif)
Mueller |
Oct 27 2003, 11:53 AM
I'm not sure, when I bought the motor I was told it was completly rebuilt and I "assumed" it had a new cam, it is a factory cam for sure.
The motor itself has (had) less than 10K miles on it. (again, so I was told) |
Oct 27 2003, 12:26 PM
914 Idiot Group: Members Posts: 14,982 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
The double-arch pattern is the typical Type IV cam wear pattern.
The notch in the end of the lobe is the typical Type IV "throw that cam away" wear pattern. I'm guessing that the "rebuild" either didn't go into the bottom end of the motor, or they re-used the old cam. --DD |
Brad Roberts |
Oct 28 2003, 03:15 AM
The next pic Mike will post... him with a small nail file making it smooth. (IMG:style_emoticons/default/laugh.gif)
B |
redshift |
Oct 28 2003, 11:35 AM
Orange Billet Lobe Implants.
"Hey dood, NICE LOBES!" M |
Lo-Fi Version | Time is now: 9th May 2024 - 07:59 AM |
