Mueller
Oct 27 2003, 11:42 AM
see the pattern on the lobes...
Is the cam failing or the lifters??
It looks like the metal was "pushed" in order to make the impression????
or is this normal??
Brad Roberts
Oct 27 2003, 11:43 AM
Normal. Not good.. but normal.
I'll bring you a cam.
B
914werke
Oct 27 2003, 11:50 AM
Mike, how old is the combo that came from. I have a couple of 100K cams that look like that.
Mueller
Oct 27 2003, 11:53 AM
I'm not sure, when I bought the motor I was told it was completly rebuilt and I "assumed" it had a new cam, it is a factory cam for sure.
The motor itself has (had) less than 10K miles on it. (again, so I was told)
Dave_Darling
Oct 27 2003, 12:26 PM
The double-arch pattern is the typical Type IV cam wear pattern.
The notch in the end of the lobe is the typical Type IV "throw that cam away" wear pattern. I'm guessing that the "rebuild" either didn't go into the bottom end of the motor, or they re-used the old cam.
--DD
Brad Roberts
Oct 28 2003, 03:15 AM
The next pic Mike will post... him with a small nail file making it smooth.
B
redshift
Oct 28 2003, 11:35 AM
Orange Billet Lobe Implants.
"Hey dood, NICE LOBES!"
M
