Ready to replace Oil Return Tubes, Any tips are graciously accepted! |
Jeffs9146 |
Oct 27 2003, 12:26 PM
Ski Bum Group: Members Posts: 4,062 Joined: 10-January 03 From: Discovery Bay, Ca Member No.: 128 |
Thanks to JP Stein, I now have 4 collapsible Oil Return Tubes that need installation. (IMG:style_emoticons/default/smilie_pokal.gif)
I have heard that removal of the old ones is as easy as squeezing them with vice grips and working them out! Is that true? (IMG:style_emoticons/default/confused24.gif) I am working on fabricating a pair of expander pliers that will assist me in expanding the new tubes into place. Are there any other tips or tricks to make this job any easier?? Thanks in advance for all of your help!! Ya'll are great! Jeff |
J P Stein |
Oct 27 2003, 02:10 PM
Irrelevant old fart Group: Members Posts: 8,797 Joined: 30-December 02 From: Vancouver, WA Member No.: 45 Region Association: None |
Assuming the headers(heat exchangers) are out of the way, it' pretty straight foreward.
Channel locks for crushing the old tubes.....this is the brutal part...crush & twist.....oh, drain the oil first:lol: Clean up the new/old tubes including the internal O rings. Coat liberialy with silicone *grease*. same, same with the other O rings. Clean out the bores....more grease. Shove in one side...as I recall, do the head side first..the small end in there...there's just enuff room to get your fingers stuck.... then the other....it's not that easy, but it can be done. Expand the tubes enuff to expose the circlip slot. Snap that puppy in place. One down, 3 to go. Don't bother putting bandaids on you knuckles till they're all done (IMG:style_emoticons/default/laugh.gif) ` |
Jeffs9146 |
Oct 28 2003, 08:45 AM
OK JP, looks like its you and me on this one! I will use your tips and hope for the best! I think I have come up with a way to save my knuckles though. I will take pictures if it works!
Thanks again! Jeff |
Lo-Fi Version | Time is now: 20th May 2024 - 04:01 AM |
