Incorrect MPS Symptons?, New one and I went from bad to worse? |
vesnyder |
Sep 11 2006, 12:57 PM
Senior Member Group: Members Posts: 680 Joined: 14-April 05 From: Cleveland, OH Member No.: 3,933 |
I just got around to installing a used MPS I recently purchased to rectify the poor gas milage I have been getting (<20 MPG?). After installing the new one the car will no longer idle and runs extremely rough. The diagnosis on my old one showed a vacuum leak, while the new one showed none. Do I have the incorect MPS? Are there other adjustments I need to make to accomodate the new MPS? Or should I just go back to the old MPS and live with the bad milage? Thanks
rmital |
Sep 11 2006, 01:24 PM
Northeast optimist Group: Members Posts: 1,947 Joined: 12-December 05 From: Park Ridge, NJ Member No.: 5,268 |
you definitely have the correct MPS for a 1973 1.7L
0 280 100 041 = VW 022 906 051 E which is interchangeable with the 049. could you timing be in the need of adjustment?? (with the nonleaking MPS) |
TravisNeff |
Sep 11 2006, 01:31 PM
You may have to re-adjust your idle mixture (the knob on the ECU), since you probably set it for a rich running engine before.
Make sure you have the valves adjusted, timing and dwell set. After that I would be checking individual components and vacuum leaks. |
rmital |
Sep 11 2006, 01:45 PM
Vance...I could send you the portion of the harness that connects to the MPS, if you think the connection might be bad.
...just not sure how much you'll need and how it'll splice in...let me know and I could ship out to you asap. |
Cap'n Krusty |
Sep 11 2006, 02:12 PM
"New"? Define "new". The Cap'n
dlo914 |
Sep 11 2006, 02:58 PM
Whatchu' lookin' at?!?! Group: Members Posts: 3,432 Joined: 6-September 04 From: San Gabriel, CA Member No.: 2,697 |
slight hijack, which #'d mps would i use for a 75' 2.0L Djet?
TravisNeff |
Sep 11 2006, 03:05 PM
slight hijack, which #'d mps would i use for a 75' 2.0L Djet? 0 280 100 043 Check http://members.rennlist.com/pbanders |
dlo914 |
Sep 11 2006, 03:07 PM
slight hijack, which #'d mps would i use for a 75' 2.0L Djet? 0 280 100 043 Check http://members.rennlist.com/pbanders sweet now to go check the two MPS i have. awesome response time (IMG:style_emoticons/default/clap56.gif) |
vesnyder |
Sep 11 2006, 04:40 PM
OK - I checked my MPS and the part numbers are as follows:
0280 100 019 VW 022 906 051A I could not find these numbers in the assortment of MPS manuals I've collected - where are they from? |
BMXerror |
Sep 11 2006, 07:42 PM
Senior Member Group: Members Posts: 1,705 Joined: 8-April 06 From: Hesperia Ca Member No.: 5,842 |
I'd first check the fuel pressure, then the manifold vacuum. This kind of thing happens a lot when a injection system has worn gradually and compensated for itself(or someone before you has compensated the cheap way). Then you throw a rebuilt part into the mix and it will barely run. Like I said, probably vacuum leaks and/or improper fuel mixure. I wouldn't really suspect a faulty MPS connector since it ran before. Just my two cents.
Mark D. |
Lo-Fi Version | Time is now: 14th May 2024 - 02:57 AM |
