Questions about stock HEs |
lincoln |
Sep 12 2006, 03:16 PM
Member Group: Members Posts: 174 Joined: 9-December 05 From: Killeen Texas Member No.: 5,253 Region Association: None |
exhaust is apart , looking at my stock HEs and where they are welded to pipes all welds are basically broken and they rattle a bit ( never notice it when they are on car) question is because they are VERY heavy, would i really need the HEs on the car? i know i hate not having any heat in winter, as well as no defroster to clear windows, but i was thinking of taking the HEs to work, cutting off all the exchanger tubing , and just running the pipes without them for now. i could also just re-weld them, but i was curious to know if anyone had re-fabbed HEs using aluminum for its light weight , welder/fab by trade so wouldnt be that hard for me to do, and then id have to fab a way to attach them, but weight savings would be nice , and i doubt they would melt . I know SS is way everyone suggests but i REALLY dont like the heaviness of the stock type HEs.
TROJANMAN |
Sep 12 2006, 03:26 PM
Looks nice in pictures......... Group: Members Posts: 5,271 Joined: 5-March 04 From: Colorado Member No.: 1,753 Region Association: None |
what year is your car?
75-76 HE's are super heavy the ssi's i have are not too heavy sounds like you need some headers |
Mueller |
Sep 12 2006, 03:33 PM
I doubt you will save much weight by removing the sheetmetal, the tubes are where all weight is.
the SSIs are lighter since with stainless you can use a thinner gauge material yet still have an exhaust that will last. |
lincoln |
Sep 12 2006, 03:39 PM
car is a 74 , was a thought , seems like the HEs part weighs a LOT more than the actual muffler part and that was with monza style exhausts , i thought originally it was the muffler part that weighed so damn much but having taken that part off i noticed how heavy the HE parts are
was thinking that i could fab alum box HE boxes kinda like tangerine has for the /6s only out of luminum and attach them sort of like M/C mufflers do on my Suzuki Marauder - that is using mesh,sealing screen tape stuff and some serious clamping clamps for a good seal |
Mueller |
Sep 12 2006, 03:41 PM
oh yea, i'm pretty sure the heat shields should NOT be welded directly to the tubes
you want some float for thermal expansion |
JPB |
Sep 12 2006, 04:57 PM
Aluminium and steel don't mix and will make your pipes rust fast where the two touch. HEs are sold all day on ebay and steel ones are extra sheep. You might find some from a member if you post a wanted add also.
(IMG:style_emoticons/default/beer.gif) Save a teener, get a winter beater. |
lincoln |
Sep 12 2006, 05:48 PM
[quote name='JPB' date='Sep 12 2006, 03:57 PM' post='770078']
Aluminium and steel don't mix and will make your pipes rust fast where the two touch. HEs are sold all day on ebay and steel ones are extra sheep. You might find some from a member if you post a wanted add also. yea i know bout alum/steel and the rust thing- what i was thinking tho was using a ceramic clay type seal to alum to steel . the rust thing only happens where the 2 meet - we used to use foam tape as a gasket on bottom dump trailers at 1 Co. i used to work for just for that purpose. anyways, while apart i found several holes in the monza type exhaust, so i made new mufflers using some real sweet chrome mufflers that used to be on my bike. fit right on the exhaust pipes where the monzas used to be, starting at bout 1 1/2 in int and exiting with bout 3 using stock modified baffles ( from Suzuki ) plus are nice chrome . fits well just under rear valance , altho the right side needs a slight tweak cuz its hanging a bit lower and out of square with the car and left muffler. also i added a port in each muffler to accomodate air/fuel meters or for ? sound is nice, not too loud, better than monzas did, cept when i lift foot off the gas, then they just sound mean (IMG:style_emoticons/default/smile.gif) ill try to find my camera and see if i can get some pics- warning tho- is a very low res cam so pics wont be the greatest. |
ChrisFoley |
Sep 12 2006, 08:21 PM
I am Tangerine Racing Group: Members Posts: 7,925 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
...alum box HE boxes kinda like tangerine has for the /6s only out of luminum... Tangerine Racing Headers are for Type 4 engines, ie. 914-4. BTW, keeping the exhaust from both sides of the engine separate is bad for performance. All 4 primary pipes should merge before going into the muffler. |
lincoln |
Sep 12 2006, 08:50 PM
piping isnt seperated- HEs bolted to the leftover piping from monza type , only i flipped the brackets to tuck the naked pipe up inside valance, and in place where the monza muffler/holes were i welded on the chrome muffs. doesnt hang lower than it used to just now the exit is beneath the valance and the cromes show beneath the valance , in truth they SHOULD be out-turned and down a bit , as right now the exit striaght , kinda like a T , with top of T being the LOS along the lines of the mufflers, and they could use being about 3 inches longer each ( mufflers). wasnt sure on the tangerines, good to know they are for a /4
thanks for heads up |
Lo-Fi Version | Time is now: 14th May 2024 - 08:18 AM |
