[quote name='JPB' date='Sep 12 2006, 03:57 PM' post='770078']
Aluminium and steel don't mix and will make your pipes rust fast where the two touch. HEs are sold all day on ebay and steel ones are extra sheep. You might find some from a member if you post a wanted add also.
yea i know bout alum/steel and the rust thing- what i was thinking tho was using a ceramic clay type seal to alum to steel . the rust thing only happens where the 2 meet - we used to use foam tape as a gasket on bottom dump trailers at 1 Co. i used to work for just for that purpose.
anyways, while apart i found several holes in the monza type exhaust, so i made new mufflers using some real sweet chrome mufflers that used to be on my bike. fit right on the exhaust pipes where the monzas used to be, starting at bout 1 1/2 in int and exiting with bout 3 using stock modified baffles ( from Suzuki ) plus are nice chrome . fits well just under rear valance , altho the right side needs a slight tweak cuz its hanging a bit lower and out of square with the car and left muffler. also i added a port in each muffler to accomodate air/fuel meters or for ?
sound is nice, not too loud, better than monzas did, cept when i lift foot off the gas, then they just sound mean
ill try to find my camera and see if i can get some pics- warning tho- is a very low res cam so pics wont be the greatest.
