Tab A into...Where the heck is slot B?, Help me get my car back together |
HelluvaEngineer |
Sep 13 2006, 04:47 PM
Newbie Group: Members Posts: 12 Joined: 27-August 04 From: Atlanta, Ga Member No.: 2,628 |
Hi all. I'm still working on that '73 I bought, which had a few parts removed, and a couple of parts lost. I have a couple of what are hopefully simple questions - easy for you 914 gurus. Please chime in if you can.
- Oil Sensors: This car has a sensor behind a black plate on the oil pan. There is a wire on that sensor connected to...nothing. This looks like a good place for an oil temp sensor, which I think is stock. Is this correct? Where does the corresponding wire punch through the firewall (or does it run to the wiring harness / relay board)? - Air box: The air box was taken off. My questions are: how does the airbox mount to the engine? I don't see any obvious connection points. This is a '73 2.0 with the square paper filter. Does the top part connect to the throttle body with some kind of band clamp? [EDIT: Duh, looked again. The bottom clamps to the engine, top clamps to the bottom. Still does flange clamp to throttle body? ] Also, the connection to the throttle body looks like a great place for an air leak, and there are vacuum hoses connected to the air box. Is there supposed to be some kind of oring or other seal in the flange on the air box? TIA!, HE (IMG:style_emoticons/default/beerchug.gif) |
Sep 13 2006, 04:52 PM
- Oil Sensors: This car has a sensor behind a black plate on the oil pan. There is a wire on that sensor connected to...nothing. This looks like a good place for an oil temp sensor, which I think is stock. Is this correct? Where does the corresponding wire punch through the firewall (or does it run to the wiring harness / relay board)? wire is green with black stripe, goes from the sender to a connector on the main harness which is on the pass. side, right under the battery tray. look for a plasitc connector that comes out of the main harness there. the wires going into the main harness is also green/black ... and yes, this is an oil-temp sender ... (IMG:style_emoticons/default/smile.gif) Andy |
AZ914 |
Sep 13 2006, 05:31 PM
914 Dumbass Group: Members Posts: 1,459 Joined: 6-January 03 From: Sunny Tucson Member No.: 98 Region Association: Southwest Region |
Regarding the airbox, mine just pushes down on the throttle body, then I clamp it to the engine. No band clamp on mine.
Bleyseng |
Sep 13 2006, 05:46 PM
both the ones I have include a bandclamp at the throttle body connection. There is a rubber boot that slides over the throttle body to seal it.
Attached thumbnail(s) |
HelluvaEngineer |
Sep 13 2006, 06:39 PM
Thanks guys. That gets me back on track.
Looks like I might have to substitute a hose clamp and some silicone while I search for the correct parts. |
So.Cal.914 |
Sep 13 2006, 06:53 PM
Looks like I might have to substitute a hose clamp and some silicone while I search for the correct parts. Just keep in mind you don't want to use silicon anywhere near gasoline, look what happened to Richard Pryor. Not really because silicon falls apart when introduced to gas. |
Lo-Fi Version | Time is now: 14th May 2024 - 04:20 PM |
