Renn Shift, Installation with center console >>> |
knilfer |
Sep 13 2006, 09:40 PM
Professional Idiot Group: Members Posts: 24 Joined: 3-August 06 From: denver, co Member No.: 6,573 |
does anyone have any pics of a Renn Shift installed with the center console? i've found pictures of the shifter installed without a console, but none with. i'm just trying to make sure that it can be done.
also, is there a quick visual inspection i can make to ensure i have a side shift rather than a tail shift? the only verification i could find is to lift the vehicle and look for the protective plastic casing on the side of the transmission [to ensure it's a side shift]. thanks in advance. jonathan |
bd1308 |
Sep 13 2006, 09:41 PM
tail shift will literally have a shaft coming out of the back of the tranny, right?
DanT |
Sep 13 2006, 09:57 PM
If your car is a 73 it ought to be a side shifter....
Unless some stupid PO back dated it to a tail shifter. |
anthony |
Sep 13 2006, 10:20 PM
2270 club Group: Benefactors Posts: 3,107 Joined: 1-February 03 From: SF Bay Area, CA Member No.: 218 |
does anyone have any pics of a Renn Shift installed with the center console? i've found pictures of the shifter installed without a console, but none with. i'm just trying to make sure that it can be done. I'd guess that you have to enlarge the hole that the shifter comes though. Rather than modifying a stock console piece it would probably make sense just to make a new one out of wood with the enlarged hole and cover it in matching vinyl. |
So.Cal.914 |
Sep 13 2006, 10:27 PM
The shifter mech's are different, the side shift IIRC has a hole on top at the rear
to access set screw. |
Sep 13 2006, 10:28 PM
Resident German Group: Admin Posts: 41,637 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
I'd guess that you have to enlarge the hole that the shifter comes though. yes, the hole in the bottom piece has to be enlarged ... (IMG:style_emoticons/default/sawzall-smiley.gif) Andy |
knilfer |
Sep 13 2006, 10:40 PM
this board is awesome! thanks all for the information so far. i'll check out my tranny tomorrow and will keep checking back for pix too.
jonathan |
double-a |
Sep 13 2006, 11:50 PM
Senior Member Group: Members Posts: 987 Joined: 15-September 03 From: vancouver, wa, usa Member No.: 1,162 Region Association: Pacific Northwest |
search for a post by craig laughlin on the subject, i believe he detailed the console modification in a posting sometime back.
~a |
Sep 14 2006, 12:32 AM
A couple of pics for you:
The tail-cover of a tail-shift transmission, viewed as if from the back of the car. You can clearly see where the linkage attaches, at the lower-left of the part: The back of a side-shift transmission, viewed from a slightly higher angle than the above pic: The linkage of the TS trans goes into the tail cover. The linkage of the SS trans goes into the side of the transmission case. --DD |
736conver |
Sep 14 2006, 01:05 AM
Advanced Member Group: Members Posts: 2,117 Joined: 25-May 03 From: SE Wisconsin Member No.: 736 Region Association: None |
does anyone have any pics of a Renn Shift installed with the center console? i've found pictures of the shifter installed without a console, but none with. i'm just trying to make sure that it can be done. also, is there a quick visual inspection i can make to ensure i have a side shift rather than a tail shift? the only verification i could find is to lift the vehicle and look for the protective plastic casing on the side of the transmission [to ensure it's a side shift]. thanks in advance. jonathan CHeck out my post awhile back that has a step by step. http://www.914world.com/bbs2/index.php?show...hl=renn+shifter |
Stuie |
Sep 14 2006, 06:11 AM
Member Group: Members Posts: 73 Joined: 19-August 06 From: Arlington, Texas Member No.: 6,688 |
[/quote] CHeck out my post awhile back that has a step by step. http://www.914world.com/bbs2/index.php?show...hl=renn+shifter [/quote] Does the shifter improve the shifting drastically? |
double-a |
Sep 14 2006, 08:49 AM
improved shifting is a function of many things: good bushings, shifter adjustment, condition of tranny, the driver, etc.
but lay the oem shifter next to a rennshift and you'll quickly have an idea which one "might" be more fun to use. there are many threads detailing the quality and craftsmanship of the rennshift. i have one (gen 2) and it's great. ~a |
knilfer |
Sep 14 2006, 10:44 AM
thanks for posting the pics of the housing. i will use those for final determination.
jonathan |
xitspd |
Sep 14 2006, 10:46 AM
Technology and Tradition 3.6 and 914-6 Group: Members Posts: 1,305 Joined: 17-November 04 From: Foothills of Mt. San Jacinto, CA Member No.: 3,136 |
Yes, sorry for this under construction pic...
Dan Attached image(s) |
736conver |
Sep 14 2006, 11:00 AM
736conver |
Sep 14 2006, 11:01 AM
736conver |
736conver |
Sep 14 2006, 11:02 AM
736conver |
Sep 14 2006, 11:03 AM
GTeener |
Sep 14 2006, 04:00 PM
914 Girl Group: Members Posts: 2,348 Joined: 25-June 04 From: SillyCon Valley Member No.: 2,249 Region Association: Northern California |
It's not a good close-up, but basically it's just carpeted in the center console. I have the padded top, but it doesn't fit and I haven't had it enlarged.
Lo-Fi Version | Time is now: 15th May 2024 - 02:58 PM |
