knilfer
Sep 13 2006, 09:40 PM
does anyone have any pics of a Renn Shift installed with the center console? i've found pictures of the shifter installed without a console, but none with. i'm just trying to make sure that it can be done.
also, is there a quick visual inspection i can make to ensure i have a side shift rather than a tail shift? the only verification i could find is to lift the vehicle and look for the protective plastic casing on the side of the transmission [to ensure it's a side shift].
thanks in advance.
jonathan
bd1308
Sep 13 2006, 09:41 PM
tail shift will literally have a shaft coming out of the back of the tranny, right?
DanT
Sep 13 2006, 09:57 PM
If your car is a 73 it ought to be a side shifter....
Unless some stupid PO back dated it to a tail shifter.
anthony
Sep 13 2006, 10:20 PM
QUOTE(knilfer @ Sep 13 2006, 08:40 PM)
I'd guess that you have to enlarge the hole that the shifter comes though. Rather than modifying a stock console piece it would probably make sense just to make a new one out of wood with the enlarged hole and cover it in matching vinyl.
So.Cal.914
Sep 13 2006, 10:27 PM
The shifter mech's are different, the side shift IIRC has a hole on top at the rear
to access set screw.
Sep 13 2006, 10:28 PM
QUOTE(anthony @ Sep 13 2006, 09:20 PM)
yes, the hole in the bottom piece has to be enlarged ...
Andy
knilfer
Sep 13 2006, 10:40 PM
this board is awesome! thanks all for the information so far. i'll check out my tranny tomorrow and will keep checking back for pix too.
jonathan
double-a
Sep 13 2006, 11:50 PM
search for a post by craig laughlin on the subject, i believe he detailed the console modification in a posting sometime back.
~a
Dave_Darling
Sep 14 2006, 12:32 AM
A couple of pics for you:
The tail-cover of a tail-shift transmission, viewed as if from the back of the car. You can clearly see where the linkage attaches, at the lower-left of the part:
Click to view attachmentThe back of a side-shift transmission, viewed from a slightly higher angle than the above pic:
Click to view attachmentThe linkage of the TS trans goes into the tail cover. The linkage of the SS trans goes into the side of the transmission case.
--DD
736conver
Sep 14 2006, 01:05 AM
QUOTE(knilfer @ Sep 13 2006, 10:40 PM)
thanks in advance.
jonathan
CHeck out my post awhile back that has a step by step.
http://www.914world.com/bbs2/index.php?show...hl=renn+shifter
Stuie
Sep 14 2006, 06:11 AM
[/quote]
http://www.914world.com/bbs2/index.php?show...hl=renn+shifter[/quote]
Does the shifter improve the shifting drastically?
double-a
Sep 14 2006, 08:49 AM
improved shifting is a function of many things: good bushings, shifter adjustment, condition of tranny, the driver, etc.
but lay the oem shifter next to a rennshift and you'll quickly have an idea which one "might" be more fun to use. there are many threads detailing the quality and craftsmanship of the rennshift. i have one (gen 2) and it's great.
~a
knilfer
Sep 14 2006, 10:44 AM
thanks for posting the pics of the housing. i will use those for final determination.
jonathan
xitspd
Sep 14 2006, 10:46 AM
Yes, sorry for this under construction pic...
Dan
736conver
Sep 14 2006, 11:00 AM
736conver
Sep 14 2006, 11:01 AM
736conver
736conver
Sep 14 2006, 11:02 AM
736conver
Sep 14 2006, 11:03 AM
GTeener
Sep 14 2006, 04:00 PM
It's not a good close-up, but basically it's just carpeted in the center console. I have the padded top, but it doesn't fit and I haven't had it enlarged.
