Dash glue |
Dash glue |
chris914 |
Sep 14 2006, 01:09 AM
Member Group: Members Posts: 489 Joined: 24-July 04 From: San Diego, CA Member No.: 2,393 Region Association: Southern California |
I'm replacing the padded dash in my car. Part of the glued down dash in front of that came up. What is everyone using to glue it back down?
Sep 14 2006, 08:36 AM
3M Trim Adhesive. If you have lots of room to work in, the spray stuff. If not, the stuff you squeeze out of a tube. Good stuff, works quite well!
--DD |
chris914 |
Sep 14 2006, 08:41 AM
Were can you buy it?
boxstr |
Sep 14 2006, 08:42 AM
FLAPS
chris914 |
Sep 14 2006, 09:00 AM
TINCAN914 |
Sep 14 2006, 09:13 AM
Summer's Commin... Group: Members Posts: 2,440 Joined: 18-August 05 From: Colorado Springs, CO. Member No.: 4,611 Region Association: Rocky Mountains |
Friendly local auto parts store. Pep Boys, Autozone, etc.. FLAPS... (IMG:style_emoticons/default/smile.gif) |
Maltese Falcon |
Sep 14 2006, 09:21 PM
Advanced Member Group: Members Posts: 4,673 Joined: 14-September 04 From: Mulholland SoCal Member No.: 2,755 Region Association: None |
Chris, I found that besides the right adhesive for the dash, I also needed good clamping and holding force to get the dash cap ( aftermarket dash cover) to sit down right. First off, I didn't use the generic silicon that came in the kit. I used a 24 hour setting epoxy.
Clamps were used , and I made 2 wooden supports (L and R) that simply wedged into the door frame and pushed down on the dashcap. The next day after all the clamps came off, the dash was perfect--and hasn't lifted since. I meant to keep the wooden supports...but the gardener pitched them (IMG:style_emoticons/default/mad.gif) Marty Attached thumbnail(s) |
chris914 |
Sep 15 2006, 10:34 AM
Chris, I found that besides the right adhesive for the dash, I also needed good clamping and holding force to get the dash cap ( aftermarket dash cover) to sit down right. First off, I didn't use the generic silicon that came in the kit. I used a 24 hour setting epoxy. Clamps were used , and I made 2 wooden supports (L and R) that simply wedged into the door frame and pushed down on the dashcap. The next day after all the clamps came off, the dash was perfect--and hasn't lifted since. I meant to keep the wooden supports...but the gardener pitched them (IMG:style_emoticons/default/mad.gif) Marty Wow, Thanks! |
Aaron Cox |
Sep 15 2006, 10:36 AM
3m Super 90....
you can get it at home depot |
Lo-Fi Version | Time is now: 28th May 2024 - 11:57 PM |
