74' relay board removal, Am I doing this right??? |
Slowpoke |
Oct 28 2003, 01:28 PM
Member Group: Members Posts: 116 Joined: 1-June 03 From: Tucson, AZ Member No.: 768 |
I'm removing the relay board in my carbed 74. It seems pretty straight forward by matching color coded wires. Except for;
#1. the light blue alternator/generator light wire. does this wire get jumped to the red, green or brown wire comming from the alternator?? #2. The two large red wires I assume are for the fuel pump relay and the defroster fan relay, right?? This will require wiring a separate relay for each, right?? #3. I'm at a lost where the two grey w/ brown strip wires are used. They were not connected to anything in my car and I can't see where they go in the engine compartment. But, they are also in the main harness. Thanks for the help. I should have three good relay boards with good covers should anyone need them. They just looked too bulky in my engine compartment. Thanks (IMG:style_emoticons/default/idea.gif) Peter |
Oct 28 2003, 01:37 PM
Resident German Group: Admin Posts: 41,625 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
we have color wire diagrams in the download section.
they also cover the relay board and the attached wires. http://www.914world.com/downloads/ helps a lot (IMG:style_emoticons/default/wink.gif) Andy |
Slowpoke |
Oct 28 2003, 04:28 PM
The blue wire goes to the D+ (red wire) on the alternator. If anyone cares. Now if I could just find that damn grey with brown strip (IMG:style_emoticons/default/mad.gif)
Slowpoke |
Oct 28 2003, 05:09 PM
gray/brown back up lite switch wires, geez what a moron (IMG:style_emoticons/default/smile.gif)
Lo-Fi Version | Time is now: 9th May 2024 - 12:38 AM |
