I'm removing the relay board in my carbed 74. It seems pretty straight forward by matching color coded wires. Except for;
#1. the light blue alternator/generator light wire. does this wire get jumped to the red, green or brown wire comming from the alternator??
#2. The two large red wires I assume are for the fuel pump relay and the defroster fan relay, right?? This will require wiring a separate relay for each, right??
#3. I'm at a lost where the two grey w/ brown strip wires are used. They were not connected to anything in my car and I can't see where they go in the engine compartment. But, they are also in the main harness.
Thanks for the help. I should have three good relay boards with good covers should anyone need them. They just looked too bulky in my engine compartment. Thanks
Peter
