Power Steering, Is there an reasonable way to do this? |
Randal |
Sep 17 2006, 07:01 PM
It is highly likely that we will be running big slicks on The Beast and want it to be a friendly driver for all sexes.
Anybody have a good solution that isn't crazy expensive? (IMG:style_emoticons/default/sawzall-smiley.gif) |
bd1308 |
Sep 17 2006, 07:07 PM
Andy will post in a minute, but the wide slicks dont affect steering that much.
At least Ive heard there inst much difference. b |
campbellcj |
Sep 17 2006, 07:10 PM
I believe there is a GT3RS steering box that will fit. Unfortunately it is spendy, $1500 IIRC.
neo914-6 |
Sep 17 2006, 07:23 PM
It is highly likely that we will be running big slicks on The Beast and want it to be a friendly driver for all sexes. Anybody have a good solution that isn't crazy expensive? (IMG:style_emoticons/default/sawzall-smiley.gif) Didn't Bill already have the Woods ~$4k PS installed? (IMG:style_emoticons/default/confused24.gif) |
Randal |
Sep 17 2006, 07:39 PM
It is highly likely that we will be running big slicks on The Beast and want it to be a friendly driver for all sexes. Anybody have a good solution that isn't crazy expensive? (IMG:style_emoticons/default/sawzall-smiley.gif) Didn't Bill already have the Woods ~$4k PS installed? (IMG:style_emoticons/default/confused24.gif) I don't think so. That is the reason for the post. Looking for alternatives. |
Randal |
Sep 17 2006, 07:41 PM
I believe there is a GT3RS steering box that will fit. Unfortunately it is spendy, $1500 IIRC. That unit is only $1,500? (IMG:style_emoticons/default/smile.gif) What does it take to install it? |
JPB |
Sep 17 2006, 07:50 PM
Steering wheels are not meant to be turned when the car is not in motion due to stress on the rack/system and wear on the tires. If one was in a mud hole then I can see the reason for stationary steering.
(IMG:style_emoticons/default/beer.gif) Keepem rolling , drive faster, and the wheel will turn easily. It only costed me two cents and your off and runnig, schweet! |
DanT |
Sep 17 2006, 07:58 PM
Steering wheels are not meant to be turned when the car is not in motion due to stress on the rack/system and wear on the tires. If one was in a mud hole then I can see the reason for stationary steering. (IMG:style_emoticons/default/beer.gif) Keepem rolling , drive faster, and the wheel will turn easily. It only costed me two cents and your off and runnig, schweet! As he said earlier this car will be running very wide tires (slicks) at AX venues and a very nice person of the fairer sex will be co-driving. While what you say about keeping the car moving is correct, I am sure that the nice lady co-driving would like some help changing directions with those big slicks at lower AX speeds. Not to mention the 90+ degree turns. (IMG:style_emoticons/default/smile.gif) |
Howard |
Sep 17 2006, 08:07 PM
Incontin(g)ent Member Group: Benefactors Posts: 5,785 Joined: 24-July 03 From: Westlake Village, CA Member No.: 943 Region Association: None |
Old wimp here. I put my street tires on Suzi for RRC. 195/65's streets instead of sticky 205/50 Azenis. Drove Mulholland twice this weekend.
Big difference in steering effort, and my V8 with 245's on the front is downright tiring. Let's figure out a way to do it. PS is good! Cheap is good! |
drive-ability |
Sep 17 2006, 08:09 PM
Senior Member Group: Members Posts: 1,169 Joined: 18-March 05 From: Orange County, California Member No.: 3,782 |
I have seen quite a few cars using electric P/S, I think the Toyota MR2 has it. I guess it could be done for peanuts and a lot of tinkering. (IMG:style_emoticons/default/driving.gif)
So.Cal.914 |
Sep 17 2006, 08:54 PM
Early fords used a pump and a piston down on the stearing link, I beleave it
could be mounted in there with a little hard work and imagination. Maybe drive the pump with an electric motor. |
Twystd1 |
Sep 17 2006, 09:10 PM
Toyota electric..
As drive-ability said. I saw one at Slits's shop. It looked like all it needed was a 12 volt + and a neutral/ground. By the looks of it. It would be really simple to install between theh steering wheel and the first universal joint. I am guessing it takes some pretty good amperage to drive it as the wire size that was going to the mechanism was at least 10 gauge. The only down side of this setup, (I think) is that the rack was never made for this kind of usage. Therefore i would think the rack life will decrease. Then again... Racks are cheap.I have three of em as spares. Thats my thoughts anyway. Clayton |
nine14cats |
Sep 17 2006, 11:32 PM
Bill Pickering -- 914-6 GT aka....Leeloo Group: Members Posts: 2,618 Joined: 10-February 03 From: Campbell, CA Member No.: 287 Region Association: None |
Putting a power steering unit into a 914 is no easy task. I invested serious money into having a working unit created. Not only does a rack have to be fabbed, so does the tub, the suspension points for attaching the rack and also you have to rearrange the pedal cluster.
We originally tried having a column driven electrical motor unit attached to the 914. This unit was out of a Saturn. Small motor, but alot of things to work out to make it right. We then looked at the Miata power racks. The could be adapted, but you have to fab quite a bit again. We also had the Woodard unit that is used in 911s mounted up. Again, not a direct fit. Tons of fabrication. All of the units except the Saturn unit required moving the MC from the pedal cluster and running a remote resevoir. All of the options were not cheap. Anywhere from $4K to $5K installed. If we stay with manual steering in The Beast we can play with tire size, stagger, scrub radius, etc....to get it to turn easier. But low speed turns in a GT type car with slicks is tough on most of the female half of the race teams. We would like to have a solution for them..... (IMG:style_emoticons/default/smile.gif) Bill P. |
McMark |
Sep 17 2006, 11:44 PM
I would think that you could (with a little work) re-aim the MC from pointing roughly at the MC to pointing above the MC. The MC actualing rod is on a pivot and as long as the throw stays roughly the same, I would think it would work. (IMG:style_emoticons/default/idea.gif)
McMark |
Sep 17 2006, 11:50 PM
Like this...
Twystd1 |
Sep 17 2006, 11:51 PM
The Toyota unit simply fabs into the steering shaft under the dash. No under car fab. No pump. Just 12 VDC as far as I know. It only has two wires to power it. It is NOT hydraulic. It's about the size of two 930 CV joints stacked on top of another.
Remind myself that I only looked at this for about 5 minutes. At that time, I had already figured out that this was by far the easiest solution to the 914 power steering solution. I forgot about it till now. I am going to look this stuff up on the net and get back to you guys on the this data...... To make sure it is correct. I'll call Slits tomorrow and see if he can post a pic or two. If he can find it in the stack of stuff he keeps. That should better explain this device. Pics tell a thousand words........ Clayton |
neo914-6 |
Sep 18 2006, 03:05 AM
Putting a power steering unit into a 914 is no easy task. I invested serious money into having a working unit created. Bill P. Invested but not used? Here's a cheaper alternative: Barry adapted Corrado VW power steering to hold the wheels while cornering hard. He runs a small business in Canada modifying Porshe and Audis. |
Britain Smith |
Sep 18 2006, 12:13 PM
Nano Member Group: Members Posts: 2,354 Joined: 27-February 03 From: Hillsboro, OR Member No.: 364 |
That car is sweet. It looks like he modified the sheetmetal around the pedal cluster to accept the new position of the steering rod. He also added a power brake assembly. Cool.
(IMG:http://memimage.cardomain.net/member_images/11/web/2303000-2303999/2303120_4_full.jpg) (IMG:http://memimage.cardomain.net/member_images/11/web/2303000-2303999/2303120_5_full.jpg) (IMG:http://memimage.cardomain.net/member_images/11/web/2303000-2303999/2303120_19_full.jpg) (IMG:http://memimage.cardomain.net/member_images/11/web/2303000-2303999/2303120_31_full.jpg) |
groot |
Sep 18 2006, 12:24 PM
Dis member Group: Members Posts: 896 Joined: 17-December 03 From: Michigan Member No.: 1,444 |
EPAS is the way to go (Electric Power Assisted Steering). One type of EPAS uses a manual rack and uses electric power to boost the steering on the column (called column-mounted EPAS). This way you keep your 914 or 911 rack and change the steering column to add the power steering.... not for the faint of heart for sure.
The Hybrid Escape has this system as does the 2008 Escape. Most systems uses more than just 12V. The Escape system is speed sensitive. When we were tuning the 2008 Escape EPAS we would plug in the computer and change the boost curve in real time. Very cool stuff and very tunable. Now there's a much easier way to reduce your steering effort with big slicks.... reduce your caster. |
Eric_Shea |
Sep 18 2006, 02:54 PM
QUOTE Like this... Britt Dodd School of Design. (IMG:style_emoticons/default/smoke.gif) (IMG:style_emoticons/default/lol3.gif) |
Lo-Fi Version | Time is now: 21st May 2024 - 07:18 PM |
