L-Jet resistor (Ballast) pack value?, cannot find this info...thanks |
Mueller |
Sep 18 2006, 12:33 AM
Of all the L-jetronic sites I've looked at, no one has an ohm value for this part, it's only mentioned (IMG:style_emoticons/default/confused24.gif)
thanks... |
bd1308 |
Sep 18 2006, 01:27 AM
3.3k I believe
I'll find out for you later (i'm going to sleep now tho) 1 watt or larger resistor, needs to support big draws. |
Mueller |
Sep 19 2006, 10:16 AM
still looking for the measured or known value...no guessing (IMG:style_emoticons/default/poke.gif) (IMG:style_emoticons/default/biggrin.gif) |
Bartlett 914 |
Sep 19 2006, 10:27 AM
Hi Mike
I have a pack I measured VW 022 906 079 I measured 6 to 7 ohms. I thought it was supposed to be higher but that is what I got. Mark |
drewvw |
Sep 19 2006, 02:15 PM
new england car guy Group: Members Posts: 1,631 Joined: 24-February 06 From: Boston, MA Member No.: 5,630 Region Association: North East States |
all i know is that the '73 2.0 resistor was 270 ohms.....probably not the same tho |
brant |
Sep 19 2006, 02:22 PM
Mike,
I'm about to attempt to put a 1.8 together in looking at the boxes of parts I didn't see the double resistor present. if the value is clearly defined... would it be possible to go to radio shack and buy a generic correctly valued resistor then? brant |
drewvw |
Sep 19 2006, 02:30 PM
QUOTE if the value is clearly defined... would it be possible to go to radio shack and buy a generic correctly valued resistor then? you should be able to. I have a bunch of different resistors and would be happy to make up some with the solderless connections and such if you want or for anybody else. I've made a bunch for my car and I like doing it. just made some for ptravanic |
brant |
Sep 19 2006, 02:46 PM
Drew,
that makes sense, but I guess I should of asked the question more accurately.. on the L-jet double pack (I know little about Ljet yet) is it really just a resistor or does it have other functions also? brant |
ClayPerrine |
Sep 19 2006, 03:30 PM
Drew, that makes sense, but I guess I should of asked the question more accurately.. on the L-jet double pack (I know little about Ljet yet) is it really just a resistor or does it have other functions also? brant I think you are confusing 2 parts. There is a double relay that supplies power. And there is a set of 4 resistors in a pack that provides current drop between the injectiors and battery voltage. Everyone here is talking about the dropping resistors. They are standard, wire wound resistors. Oh, and to whomever was looking for them. Take a quick trip to the local automotive recycler. Look for a Nissan with injection from the mid 80s. It will have a set that is electrically compatible with the 914 set. All you have to do is change the plug. |
brant |
Sep 19 2006, 03:33 PM
I think your right.
and I am/was confusing the 2 parts. I still have a lot to learn about the Ljet over the next couple of months as I try to put one back together. thanks for the clarification and tip. brant |
Bartlett 914 |
Sep 19 2006, 04:23 PM
If we are talking about the resistor pack for the injectors, there are 4 in the pack. All are tied at one end together. This is fed to +12 or ground ( I haven't looked). The wattage is a little high. I am guessing 10 to 20 watts. I doubt these will be found at Radio Shack. The ballast resistor in series to the CHT is another subject.
Mark |
bd1308 |
Sep 19 2006, 06:55 PM
I dunno, I guess my CHT was 3.3k ohms.
sorry for the mixup. |
Mueller |
Sep 19 2006, 09:47 PM
If we are talking about the resistor pack for the injectors, there are 4 in the pack. All are tied at one end together. This is fed to +12 or ground ( I haven't looked). The wattage is a little high. I am guessing 10 to 20 watts. I doubt these will be found at Radio Shack. The ballast resistor in seties to the CHT is another subject. Mark If they are not some totally odd ball number than any of the usual suspects* will have nice metal bodied units for about $5 each *Mouser, Allied, DigiKey |
bd1308 |
Sep 19 2006, 10:22 PM
Miek, thats what you need.
Sorry abotu my mistake on the measurements. I'll double check tomorrow, I broke my voltmeter/ohmmeter |
Mueller |
Sep 20 2006, 08:41 PM
6 Ohms............
I found an assembly in my junk drawer (IMG:style_emoticons/default/ohmy.gif) Since this one appears to be in good shape, no reason to make one (for now, hahaha) |
McMark |
Sep 20 2006, 09:01 PM
Does this mean you're already getting started installing it? (IMG:style_emoticons/default/mueba.gif)
bd1308 |
Sep 20 2006, 09:16 PM
you mean 6K ohms?
Mueller |
Sep 20 2006, 10:33 PM
Bartlett 914 |
Sep 21 2006, 07:18 AM
bd1308 |
Sep 21 2006, 07:30 AM
Wierd. 6 ohms it is.
Lo-Fi Version | Time is now: 15th May 2024 - 01:16 PM |
