Don't laugh How do I change my oil, in a six |
turboman808 |
Sep 22 2006, 01:38 PM
Advanced Member Group: Members Posts: 2,718 Joined: 31-January 06 From: North Jersey Member No.: 5,505 Region Association: North East States |
HAHA Yeah I know
Where do I drain the oil from. I see the oil filter so no problem there. Also is there any particular procedure I need to follow with the dry sump system? |
ptravnic |
Sep 22 2006, 01:40 PM
Senior Member Group: Members Posts: 1,231 Joined: 27-May 03 From: Chicago, IL Member No.: 747 Region Association: None |
Nate - I'm worried. This is your 1063d post and you havn't changed the oil yet? (IMG:style_emoticons/default/blink.gif)
bd1308 |
Sep 22 2006, 01:41 PM
I dunno but be prepared for like 9 quarts to come out from the various orifices.
nbscooters |
Sep 22 2006, 01:44 PM
Member Group: Members Posts: 165 Joined: 29-June 05 Member No.: 4,347 Region Association: None |
orifices meaning engine and tank.
turboman808 |
Nate - I'm worried. This is your 1063d post and you havn't changed the oil yet? (IMG:style_emoticons/default/blink.gif) It has fresh oil and I don't drive it much so I haven't bothered. I think I have drove it between 3000-4000 miles so definetly put it off long enough. |
bd1308 |
Sep 22 2006, 01:46 PM
I put around 7k on mine and just got around to changing the oil
gawd I love the t4, engine runs smooth as silk. |
ptravnic |
Sep 22 2006, 01:48 PM
heh, heh, heh (IMG:style_emoticons/default/poke.gif)
Leo Imperial |
Sep 22 2006, 01:57 PM
Do you have to use so many cuss words? Group: Members Posts: 906 Joined: 29-November 04 From: 914 Roadshow - Glen Cove NY Member No.: 3,192 Region Association: None |
Hey stop poking fun! The man has a real question. We all have to start somewhere. At least he has the nuts to ask, knowing full and well that he would be knocked down by a bunch of guys who forget that someone took the time to help them in the begining. Helping eachother is why we on this board in the first place!
Now Nate all you have to do is grab a hold of the nut thingy on the bottom of the engine and get someone to turn the car for you. Then turn the car the other way to put it back. Good luck. |
maxwelj |
Sep 22 2006, 01:58 PM
rebuilt member Group: Benefactors Posts: 278 Joined: 8-January 04 From: Owasso, OK Member No.: 1,532 Region Association: None |
The oil line to the tank should have a union type fitting near the driver's rear wheel. You'll need to take the line apart there and let it drain. You'll also need to pull the plug in the bottom of the block. Remember to check the level running after you refill.
michel richard |
Sep 22 2006, 02:07 PM
Senior Member Group: Members Posts: 1,291 Joined: 22-July 03 From: Longueuil, Québec Member No.: 936 |
You drain the oil from two places: 1) the bottom of the engine case, in the middle: there's a drain plug in the middle of a disc-like piece of steel and 2) the union that's in the middle of the oil line that goes from the oil tank to the oil cooler, it's just in front of the left rear wheel. Most of the oil will be in the tank, and will drain from the oil line, but some of it will have flowed to the engine, hence the need to drain from the engine case. Plus the oil filter, of course. HTH. |
Rusty |
Sep 22 2006, 02:23 PM
Get the oil change kit, or at a minimum have a fresh crush-washer handy for the drain plug. If you have a conversion car or an engine with the later style oil pump, you won't have a drain plug. You'll have to remove the entire plate at the bottom of the engine. Clean off any sludge on the plate. When was the last time the valves were adjusted? This might be a good time to get it all done at once. Cheers, Rusty (IMG:style_emoticons/default/smoke.gif) |
URY914 |
Sep 22 2006, 02:35 PM
I built the lightest 914 in the history of mankind. Group: Members Posts: 120,725 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
Start with a 1/2" Craftman Power drill with a 1/4" titanum bit.
Jack up the car.... (IMG:style_emoticons/default/blink.gif) |
Leo Imperial |
Sep 22 2006, 02:39 PM
Start with a 1/2" Craftman Power drill with a 1/4" titanum bit. Jack up the car.... (IMG:style_emoticons/default/blink.gif) That's not safe! You forgot the safety glasses (IMG:style_emoticons/default/biggrin.gif) |
Joe Bob |
Sep 22 2006, 03:20 PM
Whata buncha maroons.....
Call me, 805-259-7332 |
Leo Imperial |
Sep 22 2006, 03:24 PM
Nate - bring it on Sunday and we can do it.
Mike your making me feel bad (IMG:style_emoticons/default/sad.gif) |
turboman808 |
Sep 22 2006, 03:30 PM
I'm stuck at work. I haven't been home in a couple of days. May not make it on SUnday (IMG:style_emoticons/default/sad.gif)
Brando |
Sep 22 2006, 03:31 PM
Take it to jiffy lube!
Just kidding, take michel richard's advice. |
Lo-Fi Version | Time is now: 21st May 2024 - 03:25 PM |
