Quick realease, steering wheel |
J P Stein |
Sep 23 2006, 01:23 PM
I know this
ConeDodger |
Sep 23 2006, 02:39 PM
Apex killer! Group: Members Posts: 23,575 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
Trekkor |
Sep 23 2006, 04:45 PM
Pg 63 Sept 2006 Pano
Smart Racing Products $219.98 moves wheel back 2.2" I might get one too. (IMG:style_emoticons/default/idea.gif) KT |
Rough_Rider |
Sep 23 2006, 09:00 PM
Smurf Zone Group: Members Posts: 525 Joined: 16-August 04 From: Beaverton, OR Member No.: 2,547 |
Been looking into this for quite some time.
http://www.getnrg.com/ come recomended & are pretty cheap $100 ish. JP you can get one locally from Race Dezign down on TV highway. However the huge turn off for me was the horror stories of folks having wheels coming off in the hands during a event!!! |
sixnotfour |
Sep 23 2006, 09:23 PM
914 Wizard Group: Members Posts: 10,419 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
QUOTE moves wheel back 2.2" Plus the basic momo adapter,another 2.5 inches |
Jeroen |
Sep 24 2006, 06:35 AM
http://www.paragon-products.com/
very nice one (I have an identical one) no slop, very secure you can also check http://www.goingsuperfast.com |
smdubovsky |
Sep 25 2006, 09:31 AM
Member Group: Members Posts: 331 Joined: 27-September 04 From: Silver Spring, MD Member No.: 2,837 Region Association: MidAtlantic Region |
I started a thread on this on the bird board (911 or racing section?) a few months back. I have both a ~$70 netami ball type, and a $15 NRG ball type (both from ebay). They have ZERO play. Both are identical in construction (they even interchange). I remove the "street" safety button by simply taking a small set screw out. About 2" thick. Hub + QR + dished wheel is like 8" of extension for the E30 racecar - I darn near sit in the back seat of that thing.
For the 914 where I need it to be as thin as possible, I made my own hub adapter from an old steering wheel. Drilled out the rivets to get the spline part off the wheel and make a thin adapter to adapt to a momo hub patten. Then I can use the 2" QR and a flat wheel (momo prototipo) and still have it all fit. FWIW, There is the dual pin type that jack olsen uses but requires two hands to remove and isn't a simple "pull collar" type setup. But, its very thin if the application requires it. Also very expensive. FWIW2, Any of the hex or spline units will either have play or will develop it. The ~$200 sparco one sucks. SMD |
Britain Smith |
Sep 26 2006, 03:37 PM
Nano Member Group: Members Posts: 2,354 Joined: 27-February 03 From: Hillsboro, OR Member No.: 364 |
I was supposed to be looking into this one for JP...here is what I was thinking about getting:
LTB QUICK RELEASE SPLINED BLACKThis is our new design quick release, it is the best we ever had, almost no play at all and very tight mechanism, it will extend the steering wheel closer to the driver by about 3" Will work on any MOMO or Sparco steering wheel & hub. Sale price: $99.00 Anyone have any experience with this one? -Britain Attached image(s) |
Brad Roberts |
Sep 26 2006, 05:19 PM
That one is designed for a Boxster/996. You would have to do as Stephen said and cut the back out of an old steering wheel and bolt this to it.
OR.. bolt this to you current wheel adater... HUM.. that could work.. For 99.00 I would try it. Just make sure it has multi spline and not a 5 sided setup with a ton of slop. B |
smdubovsky |
Sep 26 2006, 08:16 PM
almost no play at all It will have slop - they even admit it (IMG:style_emoticons/default/blink.gif) Im tellin ya, the best one you'll find is a ball type. I got mine for $22.44 delivered from ebay (watch out, some guys charge a ton of shipping). You'll need to buy or make a hub adapter for anything you buy. Edit: I bought both my steering wheels from LTB. They have good prices on momo stuff. I think they're return policy is crap else I would have tried their QR. SMD |
sixnotfour |
Sep 26 2006, 11:10 PM
momo with smart quick
cut stock wheel(same bolt pattern as momo) with smart quick and spacer for nut. Attached image(s) |
groot |
Sep 27 2006, 10:51 AM
Dis member Group: Members Posts: 894 Joined: 17-December 03 From: Michigan Member No.: 1,444 |
I have the LTB setup with the 5-sided hex.... yes, there is play, but not too much. The spline is better for play, but doesn't extend the steering wheel back as far (at least when I bought it). It bolts straight to the Momo hub and the steering wheel to it. Very simple and very effective.
Keep the lash in perspective... there's a rag joint in your steering system..... and there are horrendous angles that the u-joints are forced to take because of the center steer setup. This designs decistion create more issues (torque and rack speed variation) with your steering than that small amount of lash. |
smdubovsky |
Sep 27 2006, 11:28 AM
Kevin,
I would agree w/ you on the issue of steering accuracy. What drives us absolutely crazy is that even if there is a tiny amount of axial play, the steering wheel will "click" over any bumps or shimmy. We can also pick up a little vibration on a long run (as the wheel goes out of balance as it wears). The rapid ticking both audibly and tactilly drives us nuts. It doesn't bother some peopler though. Not a performance problem at all, but just really annoying. FWIW, The porsche factory RS/RSR QR is trick (and $$$). If you've never seen it, its an oval stem w/ a slight wedge shape. Looks like a really simple mechanism to lock it into the hub and compensate for wear w/ no play. I think most modern car steering shafts & U-joints have that wedge shape, so thats probably where they got the idea. SMD |
groot |
Sep 27 2006, 01:52 PM
I feel no axial lash, but there is some radial lash. I have never noticed it on the track and I do consider myself pretty dialed in to steering issues.....since steering, ride and handling tuning is how I earn my living.... I'm not trying to sound snotty, but maybe that click is from something else???? maybe your pinion to rack lash is a bit too high?
I'm curious about your wheel imbalance over a long run.... is this endurance racing? I do get wheel imbalance as the tires pick up clag (thanks, David Hobbs for that term), but it goes away once I get that crap off the tires. Never had a click from my steering associated with tire imbalace.............but I never run longer than 40 minutes or so, which may explain why I never see the issue you're talking about. |
Brad Roberts |
Sep 27 2006, 02:29 PM
QUOTE there's a rag joint in your steering system. Are you referring to the universal joints? I'm hoping you are not running the rubber "bisket" (IMG:style_emoticons/default/biggrin.gif) B |
groot |
Sep 27 2006, 02:47 PM
I am running the bisket.....ummm.. I like bickets.
Actually, I'm unfamiliar with any options and haven't found the need to replace it with something else. It does add some compliance in the system....but reduces some potential binding.... |
Brad Roberts |
Sep 27 2006, 03:36 PM
I have driven 914's with and without. The without worked the best for me. I liked the "Go Kart" reaction on the wheel.
The top shaft can be bolted directly to the shaft coming out of the rack. Same bolt spacing. This does make your splines "crooked" for lack of better a term.. (real scientific I know..LoL) but that is an easy fix. Not sure how you are setting your bump steer, but this really works well if you have moved the rack up. The "bisket" is the same thickness as the rack spacers. I would imagine you are doing it out at the wheel, but you understand what I'm talking about. B |
J P Stein |
Sep 27 2006, 05:54 PM
To clarify.
Jeroen |
Sep 27 2006, 06:12 PM
I have to admit I didn't try the ball bearing type, but I have had splined ones (5 splines and more splines)
still like this one best (IMG:http://www.paragon-products.com/photos/qrhub_race-2.jpg) no slop and least chance of coming off by accident or failure yes, you need both hands to unlock it, but that's not an issue for me another advantage is that you can only put your wheel on in one way, so it's always in the right position |
Mike T |
Sep 27 2006, 06:23 PM
can't 'member Group: Members Posts: 378 Joined: 16-January 03 From: Brackney, PA Member No.: 161 |
Biskit?
Lo-Fi Version | Time is now: 4th May 2024 - 07:18 AM |
