Rear Caliper Adjuster Pics, More caliper details |
McMark |
Oct 30 2003, 04:01 AM
Here's some pics of the adjuster mechanism that is pressed into the rear caliper pistons. You have to pull it out with a lot of force and press it back in with a lot of force. Very nerve wracking!
Brad Roberts |
Oct 30 2003, 04:32 AM
The spring/cam you didnt understand makes the piston auto adjust to the wear of the brake pad. Basically it ratchets the same mechanism you adjust to set the venting clearance to keep the clearance constant with pad wear.
B |
Rusty |
Oct 30 2003, 01:09 PM
Wanted: Engine case GA003709 Group: Admin Posts: 7,941 Joined: 24-December 02 From: North Alabama Member No.: 6 Region Association: Galt's Gulch |
At the top of the assembly is a split-ring, that is held in place by 4 tabs.
If you forget to put the pads back in after bleeding and pad replacement, and start to pump the brakes - you can snap that split ring or one of the tabs! The symptom will be that the piston won't retract properly. Don't ask how I found that out. -Rusty (IMG:style_emoticons/default/smoke.gif) |
fiid |
Nov 25 2003, 10:54 PM
Turbo Megasquirted Subaru Member Group: Members Posts: 2,827 Joined: 7-April 03 From: San Francisco, CA Member No.: 530 Region Association: Northern California |
What's the best way of getting the back cover from the brake caliper off? I have stripped the allen hole, and am trying to get some liquid wrench in there.
Would you recommend putting this thing back in, or leaving it off for easier adjustment? Fiid. |
McMark |
Nov 26 2003, 01:34 AM
You can use a punch or a chisel to get it loosened up. You have to replace it or the adjuster will fall out. The ones that parts places are nice, but I like the original ones. With a little bit of high temp antiseize they shouldn't stick.
fiid |
Nov 26 2003, 02:44 AM
I was thinking of replacing it with the steel ones... how are they?
I cut a big slot in the top of it with the dremel tool and then hammered on it with a screndriver at an angle. Once it "broke" the thread rolled out easily, but the top is toast and I need something to replace it. I think I am going to head to sears and invest in some allen sockets soon. Thanks for the advice! You guys all rock. (IMG:style_emoticons/default/clap56.gif) Fiid. |
maf914 |
Nov 26 2003, 07:56 AM
Not a Guru! Group: Members Posts: 3,049 Joined: 30-April 03 From: Central Florida Member No.: 632 Region Association: None |
Many years ago I replaced the adjuster cover threaded allen plugs with hex head plugs offered by Tweeks and Automotion. They work fine. The allen plugs, which are some soft metal, had become become rounded and difficult to remove.
Mike |
davep |
Nov 26 2003, 09:20 AM
914 Historian Group: Benefactors Posts: 5,151 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
I found a VW part that is identical to the original except for the hex key size. The number is at home, so I can't tell you now. The other trick is that the calipers originally used a copper washer under the cap. The first step I use to remove the cap is to hammer it, causing it to loosen up. Then I use something to clean the crud out of the socket before using the Allen key. If there is too much crud in there, you don't get enough engagement. I like to make sure my Allen keys are in good shape, and I like to get the rounded tip removed to improve engagement. Does anyone know of a source for the internal gear?
DaveP |
McMark |
Nov 26 2003, 07:24 PM
The internal gear is the same on all the models, so anyone who sells used parts should have them.
Lo-Fi Version | Time is now: 27th May 2024 - 09:01 PM |
