Suddenly, no power at all, Ignition Switch Dead? |
Brian Mifsud |
Sep 26 2006, 10:14 PM
Mechanical Engineer Group: Members Posts: 981 Joined: 3-March 03 From: Penngrove, CA Member No.: 384 Region Association: None |
I had just switched off my previously perfectly starting engine to go get some wrenches to adjust fuel pressure regulator. A moment later, I turn the key and get absolutely NOTHING.. no idiot light, no starter, no fuel pump....
If there is a significant blockage to flow for the fuel pump, would that kill some "master" fuse so I have absolutely no power? Pump was only running literally for 10 seconds. The front end is on jack stands so car isn't level. I know somewhere is a switch that kills the fuel pump if you wreck.. is this a mercury bubble type? I've never had any problems with my ignition switch of any sort before. No puffs of smoke..nothing... |
Lo-Fi Version | Time is now: 17th May 2024 - 06:28 AM |
