I had just switched off my previously perfectly starting engine to go get some wrenches to adjust fuel pressure regulator. A moment later, I turn the key and get absolutely NOTHING.. no idiot light, no starter, no fuel pump....
If there is a significant blockage to flow for the fuel pump, would that kill some "master" fuse so I have absolutely no power? Pump was only running literally for 10 seconds. The front end is on jack stands so car isn't level. I know somewhere is a switch that kills the fuel pump if you wreck.. is this a mercury bubble type?
I've never had any problems with my ignition switch of any sort before.
No puffs of smoke..nothing...
