New Fiberwerks Twin Barrel Cooling System, Anyone know of this? |
Leo Imperial |
Sep 27 2006, 06:09 PM
Do you have to use so many cuss words? Group: Members Posts: 906 Joined: 29-November 04 From: 914 Roadshow - Glen Cove NY Member No.: 3,192 Region Association: None |
I found this on ebay. I was wondering if their is any info floating around. Some cooling options were being discussed earlier today and figured I would throw this into the mix.
Porsche 914 New Fiberwerks Twin Barrel Cooling System (IMG:style_emoticons/default/popcorn[1].gif) Attached image(s) |
JPB |
Sep 27 2006, 06:13 PM
Jeroen |
Sep 27 2006, 06:15 PM
it's not new and IIRC, Zois had it on one of his 4 bangers
So.Cal.914 |
Sep 27 2006, 06:16 PM
Maybe if you could install a monometer on eather side so you would know if the
fans quit. |
Jake Raby |
Sep 27 2006, 06:17 PM
I'd pay someone to let me borrow one for a day on the dyno.
I know what the results will be, but would like to prove it. |
Mark Henry |
Sep 27 2006, 06:19 PM
Junk
Electric fan can not do the job |
Mark Henry |
Sep 27 2006, 06:21 PM
JPB |
Sep 27 2006, 06:32 PM
It probably works great at high continous RPMs but it would be to cold for street applications.
(IMG:style_emoticons/default/beer.gif) |
Mike T |
Sep 27 2006, 06:34 PM
can't 'member Group: Members Posts: 378 Joined: 16-January 03 From: Brackney, PA Member No.: 161 |
Who's 914 is that in the background?
Jake Raby |
Sep 27 2006, 07:41 PM
It probably works great at high continous RPMs but it would be to cold for street applications. (IMG:style_emoticons/default/beer.gif) Nope... Load= heat. Those fans move alot of CFM, but don't make any pressure at all. Pressure is what forces air where it generally does not want to go, into the nooks and crannnies of the cylinders and heads... Its time to kill the myth- I'm ordering one tomorrow. I'll test it against a stock system and a DTM on the same 160+ HP engine. The datalogger doesn't lie- |
john rogers |
Sep 27 2006, 07:51 PM
Senior Member Group: Members Posts: 1,525 Joined: 4-March 03 From: Chula Vista CA Member No.: 391 |
I would not throw too many stones at it without some testing as the Wayne Baker #22 IMSA 914 used a pair of relocated heater/vent fans blowing over the barrels and head area. They were in the passenger seat location and ducted through the firewall. The oil cooler took care of cooling the case.
Andyrew |
Sep 27 2006, 08:25 PM
Good job jake!!
Low RPMS it'll be fine.. But it cant push as much air reliably as fans at 7k rpms. And what happens when an electric fan goes out? |
Jake Raby |
Sep 27 2006, 08:27 PM
I would not throw too many stones at it without some testing as the Wayne Baker #22 IMSA 914 used a pair of relocated heater/vent fans blowing over the barrels and head area. They were in the passenger seat location and ducted through the firewall. The oil cooler took care of cooling the case. Baker's system was way different..He also had air ducted into the area from the front of the car |
McMark |
Sep 27 2006, 08:38 PM
I'm willing to throw some $ in to get that thing tested. I sent you an email Jake. (IMG:style_emoticons/default/thumb3d.gif)
Lou W |
Sep 27 2006, 08:44 PM
"Here Kitty Kitty" my ass...... Group: Members Posts: 4,109 Joined: 9-May 04 From: Roseburg, OR. Member No.: 2,039 Region Association: Spain |
Its time to kill the myth- I'm ordering one tomorrow. I'll test it against a stock system and a DTM on the same 160+ HP engine. The datalogger doesn't lie- You're the man Jake can do it, yes he can....ah shit, I forgot the rest...oh well (IMG:style_emoticons/default/piratenanner.gif) (IMG:style_emoticons/default/piratenanner.gif) (IMG:style_emoticons/default/piratenanner.gif) |
turboman808 |
Sep 27 2006, 08:47 PM
Advanced Member Group: Members Posts: 2,718 Joined: 31-January 06 From: North Jersey Member No.: 5,505 Region Association: North East States |
it looks cool but I wouldn't trust it.
With some ducts it might work better. (IMG:style_emoticons/default/confused24.gif) |
gregrobbins |
Sep 27 2006, 08:53 PM
Member: Team NARP Group: Members Posts: 1,515 Joined: 23-March 04 From: Arizona Member No.: 1,844 Region Association: Southwest Region |
I would not throw too many stones at it without some testing as the Wayne Baker #22 IMSA 914 used a pair of relocated heater/vent fans blowing over the barrels and head area. They were in the passenger seat location and ducted through the firewall. The oil cooler took care of cooling the case. Baker's system was way different..He also had air ducted into the area from the front of the car Ron Mistak now owns the car and it runs three fans. Two located in the passenger seat area, one each blowing through two hoses to the left and right side of the motor and one in the rear plowing on the two back cylinders. Attached image(s) |
Jake Raby |
Sep 27 2006, 08:58 PM
Those radial fans have much better pressure characteristics than the large volume axial fans used in system in question.
We'll be busting this myth pretty damn quick! I want to wait till the new dyno is set up before I run the tests though, it'll be much easier, and faster than the current dyno set up. |
Mueller |
Sep 27 2006, 09:29 PM
Leo is guilty as is pretty much everyone that has ever asked about this fan or other questionable items without addressing this:
Is this item okay for..... 1) Race car? 2) Street car? 3) Both? The generalization of "will this work"? is beyond vague...you need to ask "will it work in my application" (state application) I like the idea of converting this fan to belt drive if it would work (IMG:style_emoticons/default/welder.gif) (IMG:style_emoticons/default/smash.gif) |
Hydra |
Sep 28 2006, 12:42 AM
Quia nominor LEO Group: Members Posts: 162 Joined: 11-December 04 Member No.: 3,261 |
I thought i read somewhere that those belt driven fans become less efficient as rpm increases....
provided those electric fans give enough air displacement, i guess one could duct air in a way to get higher pressures at sensible points in the engine... using diffusers and such... |
Lo-Fi Version | Time is now: 28th May 2024 - 05:28 AM |
