I've spent a significant portion of my career as a Thermal Engineer desiging, building and testing air cooling systems.
An electric fan only makes sense for a someone who doesn't mind expending MORE energy (i.e. gas) to cool their engine for the sake of quick bursts of acceleration (i.e. autocrossers and drag racers).
An efficiently designed blower (914's use blowers, not fans) moves lots of air at high pressure. If I took that same impeller (the spinning part of a blower), and hooked up the properly sized electric motor, I'm guaranteed to use up more fuel right off the bat because of the inefficiecy of an alternator and electric motor. Both create heat while generating or consuming power.
An ADVANTAGE of using an electric motor, is that the battery acts as a "reservoir" or dampner. When I hit the gas on an electrically powered air cooled motor, there isn't any initial additional charging load on the alternator (since the battery acts as the reservoir). I'm therefore freed up of the load on my crankshaft (temporarily) to allow more torque to accelerate the car. Very soon however, the battery will deplete enough that the alternator will be under full load, robbing the drivetrain of horsepower. You CANNOT get more efficient than mounting the impeller directly on the crank. BTW, if you do choose to use a belt drive for a horizontal fan, (ala Corvair, or 917) use one of those linked "tinkertoy" belts you see on "Norm's Shop", they (or their automotive equivalent) have been proven to be more efficient than a plain V-Belt.
Most cars today have electrically cooled radiator fans...however, they all have the radiators sitting in the airstream from the vehicle moving down the road. The electric fan is really only needed when you are stuck in traffic with engine idling (notice those gigantic fans you always see on chassis dynos?, the electric fan CANNOT generate the airstream needed to cool the radiator of an engine under load).
Unless you are an autocrosser, using electric cooling fans on a 914 is fuel wasting mistake.
A side note... the Beetles used welded steel sheetmetal impellers. These are better than fans, but are still nowhere near as efficient as the die-cast 914 impeller. All those little airfoils are big steps up from the "vanes" used by the Beetle. The only way to make the 914 blower a MORE efficient pumping system is to redesign it for a specific RPM. The idea of knocking out every other blade is a crude effort to take load off the crank, but in doing so, you are losing significant pressure.
Side note #2.. my favorite "Cooling Enhancement" I've ever seen on a 914 was at an PCA Autocross at Candlestick park. One guy had taken a piece of 6" HVAC ducting, and cut holes in a straight line from his front bumper, through the firewalls, and a straight shot right into the blower's intake.....
