its HOT in here!, heater valve flappers |
SGB |
Oct 2 2006, 10:05 AM
Last year my heat wouldn't shut off. The asbestos sealing surface inside the flapper had come loose and lodged inside to hold the valve open. I took out the offending peice, but left the whole system unplugged from the rest of the car. It is getting cooler, so I reattatched the valves. Now, even in closed position, quite alot of heat gets through. I need ideas on what material to use to make replacement seals. Anybody been down this road already?
ptravnic |
Oct 2 2006, 10:28 AM
Senior Member Group: Members Posts: 1,231 Joined: 27-May 03 From: Chicago, IL Member No.: 747 Region Association: None |
are the springs in the flapper box allowing it to close? I've never had a prob w/too much heat and the asbestos is gone from mine too.
VWnDRAG |
Oct 2 2006, 10:34 AM
Member Group: Members Posts: 69 Joined: 23-September 05 From: Hollywood, CA Member No.: 4,850 |
PelicanParts.com is the best way to go.
About 80 bucks for a whole new heater valve assy. Part # 022-256-205-B-M350 (left) Part # 022-256-206A-M350 (right) Attached image(s) |
SGB |
Oct 2 2006, 02:22 PM
Lo-Fi Version | Time is now: 27th May 2024 - 06:40 PM |
