Last year my heat wouldn't shut off. The asbestos sealing surface inside the flapper had come loose and lodged inside to hold the valve open. I took out the offending peice, but left the whole system unplugged from the rest of the car. It is getting cooler, so I reattatched the valves. Now, even in closed position, quite alot of heat gets through. I need ideas on what material to use to make replacement seals. Anybody been down this road already?
ptravnic
Oct 2 2006, 10:28 AM
are the springs in the flapper box allowing it to close? I've never had a prob w/too much heat and the asbestos is gone from mine too.
VWnDRAG
Oct 2 2006, 10:34 AM
PelicanParts.com is the best way to go.
About 80 bucks for a whole new heater valve assy.
Part # 022-256-205-B-M350 (left)
Part # 022-256-206A-M350 (right)
QUOTE(ptravnic @ Oct 2 2006, 11:28 AM)
I don't know. Good idea!
New flappers would be nice, but the $160 should go toward the impending trans rebuild first...
