Shift linkage condition, This can't be right! |
Bartlett 914 |
Oct 3 2006, 11:01 AM
I have 3 Shift linkages. 1 it really bent. The other 2 are nearly identical. I can't believe this shape is correct. I made a shaft to fit where the front shift would fit. Using the floor tiles as a reference, you can see that they are not parallel. Does anyone have a drawing of what this shape should be.
Mark Attached image(s) |
Bartlett 914 |
Oct 3 2006, 11:03 AM
The picture is cropped too much to see the shaft I made. Frome the knuckle there is a shaft inserted and that shaft is parallel to the line on the floor tiles.
Mark |
gms |
Oct 3 2006, 11:37 AM
Advanced Member Group: Members Posts: 2,695 Joined: 12-March 04 From: Chicagoland Member No.: 1,785 Region Association: Upper MidWest |
they are designed with a lot of bends (from the factory)...you can compare them to mine if you would like.
Joe Ricard |
Oct 3 2006, 11:57 AM
Yes but the two ends need to be on the same axis.
cooltimes |
Oct 3 2006, 02:40 PM
Advanced Member Group: Members Posts: 2,508 Joined: 18-May 04 Member No.: 2,081 Region Association: None |
Pelican has a drawing showing it. See link for diagram.
http://www.pelicanparts.com/914/Parts/Peda...ge_side_big.htm MikeCool I have 3 Shift linkages. 1 it really bent. The other 2 are nearly identical. I can't believe this shape is correct. I made a shaft to fit where the front shift would fit. Using the floor tiles as a reference, you can see that they are not parallel. Does anyone have a drawing of what this shape should be. Mark |
Bartlett 914 |
Oct 3 2006, 03:07 PM
[quote name='cooltimes' date='Oct 3 2006, 12:40 PM' post='786648']
Pelican has a drawing showing it. See link for diagram. http://www.pelicanparts.com/914/Parts/Peda...ge_side_big.htm MikeCool Thanks for the link. I didn't see any dimensions only an exploded view. Was there something else I missed? Mark |
cooltimes |
Oct 3 2006, 03:45 PM
I was thinking you were asking about the offset shape in relation to linear alignment of the part. I wish I could give you that info but mine is a tailshifter. What Joe said is true. Both ends need to be on the same plane.
No dimensions are there or anyplace I know of. However I will keep looking around globally and see if there is any actual measurements anywhere that my surfing could luck up on. Never know what you'll find on the Internet. MikeCool "Thanks for the link. I didn't see any dimensions only an exploded view. Was there something else I missed?" Mark [/quote] |
Lo-Fi Version | Time is now: 27th May 2024 - 07:25 PM |
