Bartlett 914
Oct 3 2006, 11:01 AM
I have 3 Shift linkages. 1 it really bent. The other 2 are nearly identical. I can't believe this shape is correct. I made a shaft to fit where the front shift would fit. Using the floor tiles as a reference, you can see that they are not parallel. Does anyone have a drawing of what this shape should be.
Mark
Bartlett 914
Oct 3 2006, 11:03 AM
The picture is cropped too much to see the shaft I made. Frome the knuckle there is a shaft inserted and that shaft is parallel to the line on the floor tiles.
Mark
they are designed with a lot of bends (from the factory)...you can compare them to mine if you would like.
Joe Ricard
Oct 3 2006, 11:57 AM
Yes but the two ends need to be on the same axis.
cooltimes
Oct 3 2006, 02:40 PM
Pelican has a drawing showing it. See link for diagram.
http://www.pelicanparts.com/914/Parts/Peda...ge_side_big.htmMikeCool
QUOTE(Bartlett 914 @ Oct 3 2006, 12:01 PM)
Mark
Bartlett 914
Oct 3 2006, 03:07 PM
[quote name='cooltimes' date='Oct 3 2006, 12:40 PM' post='786648']
Thanks for the link. I didn't see any dimensions only an exploded view. Was there something else I missed?
Mark
cooltimes
Oct 3 2006, 03:45 PM
I was thinking you were asking about the offset shape in relation to linear alignment of the part. I wish I could give you that info but mine is a tailshifter. What Joe said is true. Both ends need to be on the same plane.
No dimensions are there or anyplace I know of. However I will keep looking around globally and see if there is any actual measurements anywhere that my surfing could luck up on. Never know what you'll find on the Internet.
MikeCool
"Thanks for the link. I didn't see any dimensions only an exploded view. Was there something else I missed?"
Mark
[/quote]
