billet oil filters, Need two |
Randal |
Oct 4 2006, 02:21 PM
What we are looking for is a billet oil filter adapter allowing two (dual) filters.
One alternative is the Canton adapter and high volume filter, which is "O" ringed. Thanks in advance for you help. |
Matt Romanowski |
Oct 4 2006, 02:27 PM
Senior Member Group: Members Posts: 878 Joined: 4-January 04 From: Manchester, NH Member No.: 1,507 |
Why does it have to be billet?
Mark Henry |
Oct 4 2006, 02:28 PM
Jegs?
Randal |
Oct 4 2006, 02:41 PM
Why does it have to be billet? It doesn't, but if someone is building a dual billet oil filter, with "o" rings, you know the quality is going to be better. The question is why build a very very ($$$$$) engine and put stuff on it that that isn't high quality with absolute performance in mind. I mean why stop spending money now (IMG:style_emoticons/default/wacko.gif) |
Mueller |
Oct 4 2006, 02:42 PM
Why does it have to be billet? do you have a cast one, if so share the info (IMG:style_emoticons/default/smile.gif) |
Brad Roberts |
Oct 4 2006, 02:46 PM
Mueller,
can you look into making something that bolts to a 914 oil filter console and uses a Boxster oil filter? They are cartridges and are more friendly to the enviroment when thrown away (no steel) Maybe something that bolts onto the stock block area and can use a Boxster plastic thread on holder and the cartridge style filter. Just thinking out loud here... B |
eeyore |
Oct 4 2006, 03:32 PM
Are the filters going to be in series or parallel? Or, one for scavenge, one for pressure?
Matt Romanowski |
Oct 4 2006, 03:45 PM
I thought Moroso used to make one, but I can't find it. Amsoil makes billet ones designed for diesels.
http://www.amsoil.com/bypassfilters/instructions/BP137.pdf If you want one for suction and one for pressure, you are better off using one of the little suction filters. I think Canton Meca makes them. |
Randal |
Oct 4 2006, 04:54 PM
sixnotfour |
Oct 4 2006, 06:13 PM
914 Wizard Group: Members Posts: 10,432 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
McMark |
Oct 5 2006, 01:10 AM
Jeff, that's cool!
(IMG:http://www.petersonfluidsys.com/Photos/filt_dualbrkt.jpg) And you can get the filter elements anywhere from 100 to 45 microns. (IMG:style_emoticons/default/drooley.gif) |
cnavarro |
Oct 5 2006, 01:12 PM
Cylinder Guru Group: Members Posts: 472 Joined: 30-December 02 From: Chicagoland! Member No.: 49 Region Association: None |
100 to 45 microns - you can drive a piston through that element. I'll stick to good 'ol paper or synthetic impregnated media thank you :-)
McMark |
Oct 5 2006, 01:17 PM
How many microns is a paper element? (IMG:style_emoticons/default/confused24.gif)
Matt Romanowski |
Oct 5 2006, 01:27 PM
Canton Mecca is down to 8 microns.
McMark |
Oct 5 2006, 01:36 PM
Ah, shit. Well forget the (IMG:style_emoticons/default/drooley.gif) then. Make it a (IMG:style_emoticons/default/barf.gif)
sixnotfour |
Oct 7 2006, 10:01 AM
QUOTE What we are looking for is a billet oil filter adapter allowing two (dual) filters. QUOTE Jeff, that's cool! QUOTE Ah, shit. Well forget the then. Make it a Mark , I meant the link to show their billet filter mounts that take a screw on filter of choice, I like their's because they use the oringed AN fittinge instead of the standard pipe thread. sorry you got caught eyeballing the racer stuff. |
Lo-Fi Version | Time is now: 19th May 2024 - 07:50 AM |
