Need help removing tie rods |
watsonrx13 |
Oct 5 2006, 05:58 PM
Advanced Member Group: Members Posts: 2,734 Joined: 18-February 03 From: Plant City, FL Member No.: 312 Region Association: South East States |
OK, I've removed the castellated nut, added PB Blaster for the last 3 days, placed a jack stand underneath the front brake disc, pounded on the side of the spindle where the tie rod bolt goes through, used a gear puller type tie rod removal tool, but still no movement.
Any other recommendations. BTW, I'll be replacing the tie rod with a turbo version... -- Rob |
Allan |
Oct 5 2006, 06:02 PM
Get a pickle fork.
You're going to end up replacing the tie-rod ends anyway. You can get one cheap at any flaps and it'll make short work of the seperation. |
watsonrx13 |
Oct 5 2006, 06:25 PM
Get a pickle fork. You're going to end up replacing the tie-rod ends anyway. You can get one cheap at any flaps and it'll make short work of the seperation. Thanks Allan, I'll try that next.... (IMG:style_emoticons/default/smile.gif) |
watsonrx13 |
Oct 9 2006, 03:54 PM
Allen, success.... (IMG:style_emoticons/default/mueba.gif)
I used the pickle fork and a 3# (IMG:style_emoticons/default/smash.gif) .... BTW, I also jacked up the control arm and put a jack stand underneath the brake disc to relieve the pressure from the tie-rod ends.... The front suspension is now removed..... time for a refreshment.... (IMG:style_emoticons/default/beer3.gif) If anyone is interested in the progress of this project and any others I've done, please check my signature for my website.... -- Rob |
Joe Ricard |
Oct 9 2006, 06:45 PM
Hey Rob, I think you hit it one too many times. The whole freaking suspension fell out.
Man I'm not messing with you no more. |
PORobinSCHE |
Oct 9 2006, 06:48 PM
Member Group: Members Posts: 421 Joined: 22-July 06 From: Orlando,Fl Member No.: 6,484 |
isn't that the car you just bought? already broken?? (IMG:style_emoticons/default/confused24.gif)
Lo-Fi Version | Time is now: 21st May 2024 - 08:30 AM |
