PLEASE HELP!, Car won't stay running and I'm out of ideas. |
RockinOldSchool |
Oct 7 2006, 10:45 PM
914 Junkie Group: Members Posts: 203 Joined: 2-August 06 From: Whatcom County, WA Member No.: 6,562 Region Association: Pacific Northwest |
Please keep in mind I'm still a newb when it comes to teeners. Most experience is from my bug and my infiniti.
I replaced my AAR yesterday and blew a fuse (I think for the fuel pump?) on the relay board. (I'm a smart one and forgot to shut off the power first. (IMG:style_emoticons/default/headbang.gif) ) I replaced it and now when I go to start the car it cranks, fires then dies about 1 1/2 seconds later. My friend came over and swapped his relay board into my car and it still does the same. For the basics, it's a 2 liter D-jet. Has 5 gallons of gas in the tank so it's far from out, ran fine before I swapped the AAR and blew the fuse. I figure I might've knocked something loose while I was in there but have yet to find any loose connections or otherwise. Any ideas guys? Thanks in advance. |
jd66921 |
Oct 8 2006, 09:42 AM
Member Group: Members Posts: 316 Joined: 9-January 06 From: Texas Member No.: 5,394 |
Please keep in mind I'm still a newb when it comes to teeners. Most experience is from my bug and my infiniti. I replaced my AAR yesterday and blew a fuse (I think for the fuel pump?) on the relay board. (I'm a smart one and forgot to shut off the power first. (IMG:style_emoticons/default/headbang.gif) ) I replaced it and now when I go to start the car it cranks, fires then dies about 1 1/2 seconds later. My friend came over and swapped his relay board into my car and it still does the same. For the basics, it's a 2 liter D-jet. Has 5 gallons of gas in the tank so it's far from out, ran fine before I swapped the AAR and blew the fuse. I figure I might've knocked something loose while I was in there but have yet to find any loose connections or otherwise. Any ideas guys? Thanks in advance. I had a similar problem on my L-Jet. I had pulled the wires out of the AAR by mistake and they shorted out. That caused the whole car to shut down after a second or so. The key was that I noticed the alternator and oil pressure lights shut off, indicating a total loss of electricity. Might want to check something like that. Jeff |
RockinOldSchool |
Oct 8 2006, 12:29 PM
I had a similar problem on my L-Jet. I had pulled the wires out of the AAR by mistake and they shorted out. That caused the whole car to shut down after a second or so. The key was that I noticed the alternator and oil pressure lights shut off, indicating a total loss of electricity. Might want to check something like that. Jeff I'll double check that wiring, thanks for the lead. But if I remember correctly I pulled the AAR back off and it was still dieing rather than just high idling like it should with the AAR off. And far as alternator and oil pressure lights, the P.O. made his own wiring harness and didn't wire them in. So until I have some time to run the wires i'm out of luck for those two. I'm in no way talking crap. Chris did an excellent job on the car. The wiring has just aged a bit. |
rhodyguy |
Oct 8 2006, 02:32 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,081 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
john, is the fuel pump running? you can check that easily by going to the classic threads. look up andy's pump power jumper wire trick for carbed cars. the pump is powered when the key is turned to the on position. atleast i think it will work.
k |
RockinOldSchool |
Oct 8 2006, 02:35 PM
john, is the fuel pump running? you can check that easily by going to the classic threads. look up andy's pump power jumper wire trick for carbed cars. the pump is powered when the key is turned to the on position. atleast i think it will work. k i was actually just about to do this. The pump primes but i don't know if it stays running or not. i'll post back when I know. |
RockinOldSchool |
Oct 8 2006, 03:32 PM
So I just jumped the fuel pump via SirAndy's carb trick. The fuel pump is running fine.
However while installing the new fuse the other night I accidentally arced between the fuse terminal shown on the following picture and the volatage regulator casing through a 25amp fuse. That wouldn't fry the f.i. brain would it? (I'm always forgeting that almost everything on the car gets powered on when the battery kill is turned on. And I have the bad habit of forgeting to turn it off when I'm working on the car.) See in yellow. From arrow to arrow through a 25amp fuse. And the pic is from someone else's engine bay. I just used it for reference. (IMG:http://i49.photobucket.com/albums/f284/johnkup/Untitled-1-1.jpg) |
RockinOldSchool |
Oct 8 2006, 03:56 PM
So I just jumped the fuel pump to run continuously with the f.i. harness still on the relay board and started the car and it is still reacting the same.
See picture above in red for how the fuel pump was jumped. Ran a wire from the existing harness to the ground. |
swl |
Oct 8 2006, 04:22 PM
Senior Member Group: Members Posts: 1,409 Joined: 7-August 05 From: Kingston,On,Canada Member No.: 4,550 Region Association: Canada |
any chance you could have disturbed the wires to the trigger points?
RockinOldSchool |
Oct 8 2006, 04:29 PM
Bleyseng |
Oct 8 2006, 05:20 PM
Check your basic stuff...
Pull and injector and stick it in a jar, pull the main coil wire and turn over motor to see if you are getting fuel. |
IronHillRestorations |
Oct 8 2006, 07:32 PM
I'd check fuel pressure in the loop. Just because the fuel pump is running doesn't mean it's giving enough pressure.
RockinOldSchool |
Oct 11 2006, 01:01 AM
Well I swapped in another ecu (same part #) and it's still suffering the same problem. So check that possibility off of the list. So first thing after class tomorrow I'm swapping out the fuel pump to see if that makes any difference.
Rick L |
Oct 11 2006, 10:09 AM
Member Group: Members Posts: 405 Joined: 12-November 05 From: Columbia-ish, MD Member No.: 5,116 Region Association: North East States |
Had this problem after changing an alternator once. Like you I'm a smart one...I forgot to plug the air controler harness back in. It did exactly the same thing. I'd check there.
john rogers |
Oct 11 2006, 10:51 AM
Senior Member Group: Members Posts: 1,525 Joined: 4-March 03 From: Chula Vista CA Member No.: 391 |
Check the fuel pressure with a gauge, just swapping the pump may not help if the lines are plugged or kinked or???
RockinOldSchool |
Oct 11 2006, 10:55 AM
Check the fuel pressure with a gauge, just swapping the pump may not help if the lines are plugged or kinked or??? Shouldn't have any plugged or kinked lines. The car was running fine until I replaced the AAR and arced the fuse. Ran fine with the old AAR out before I put in the new one as well. I think my problem is that I knocked something loose and am just over looking it or I fried something electronically. |
cooltimes |
Oct 11 2006, 10:58 AM
Advanced Member Group: Members Posts: 2,508 Joined: 18-May 04 Member No.: 2,081 Region Association: None |
Like 2 others have already said. Check the fuel pressure with a gage. The fuel filter been replaced lately? Check it?
MikeCool |
swl |
Oct 11 2006, 05:16 PM
just thinking out loud John.
You always get a brief run but it dies out almost immediately right? That means you are getting fuel delivery of some sort. Where would it come from? Assuming that it is not really cold there it won't be from the cold start valve - that doesn't kick in until it is almost freezing iirc. You get a blast on all four injectors when you key on. I'm thinking that that is where you are getting that start gas from. The other possible source is from the tps. It gives a series of enrichment jolts as you go from off throttle to full throttle. I don't know if this hits all four injectors or just the two turned on by the the trigger points but I think it goes to all 4. Just for giggles why don't you see if you can keep it sort of running by kicking the throttle a few times. |
RockinOldSchool |
Oct 11 2006, 06:04 PM
Just for giggles why don't you see if you can keep it sort of running by kicking the throttle a few times. Tried and it still died. Been attempting to start it each time I try something new. Won't even start now. Cranks, but won't start. So far: Replaced the fuel filter tried another ecu tried another fuel pump tried another relay board Can't measure fuel pressure because I don't have a pressure gauge and don't have the money to buy one right now. (IMG:style_emoticons/default/dry.gif) I've just about run out of ideas as to what the cause could be. (IMG:style_emoticons/default/confused24.gif) Not to mention if I don't make it up to Bellingham tomorrow or friday afternoon i'm in big trouble with the girlfriend. (IMG:style_emoticons/default/sad.gif) |
swl |
Oct 11 2006, 07:55 PM
damn - can't have you in trouble with the girlfriend!
Have you done the 'squirt in a bottle'. remove the feed to the coil, pull an injector aim it into a bottle and crank the engine. You should see a really solid spray from the injector. perhaps even before that. Key on, operate the throttle and listen for the injectors to fire. If you don't hear anything then the problem is definitely electrical not fuel. How's the battery holding up through all this? |
effutuo101 |
Oct 11 2006, 08:43 PM
Advanced Member Group: Members Posts: 2,734 Joined: 10-April 05 From: Lemon Grove Member No.: 3,914 Region Association: Southern California |
Hey John,
Also check the battery cut off switch, they are known to go bad, although I have never heard of a case where you can get the motor to run for a few seconds and then cut out. What is the coil temp like? If I think of anything, I will drop you a line |
Lo-Fi Version | Time is now: 21st May 2024 - 08:59 PM |
